Test & Tools
Test & Tools
Documents ABI - LINEARMASTER PRO - TESTER, IC , digital user manual
  • Author Author: RenfordNel
  • Date Created: 29 Feb 2012 5:23 PM Date Created
  • Last Updated Last Updated: 20 Feb 2014 5:01 PM
  • Views 1486 views
Analogue and Digital Handheld IC Testing
State of the Art Technology
Very large scale integration allows advanced functionality and ease of use to be combined in the Compact Professional Range’s hand-held, battery operated units.
The 2 line x 16 character dot matrix LCD shows the result of the test as a 'PASS' or 'FAIL' together with individual device pin diagnostics, test mode and possible equivalents.
LinearMaster Compact Professional – Handheld Linear IC Tester
Comprehensive Test
The LinearMaster Compact Professional emulates passive circuitry around the device under test to
ensure that a comprehensive test takes place. High integrity verification offers guaranteed levels of
reliability in the results. Conditional and unconditional loop testing modes ensure that intermittent and/or temperature related faults are detected.
Auto Identification
The LinearMaster Compact Professional automatically senses the functionality of the device to be tested and displays a list of possible equivalents for replacement. Unmarked and house-coded Ics are easily identified and tested.
As part of the IC test, the specific IC number, the functional description of the device and the status
of faulty pins are scrolled through on the built-in display.
  • Auto identification mode identifies unmarked/house-coded devices listing possible replacements
  • Conditional/unconditional loop testing mode
  • Functional test unit emulates passive circuitry to implement a comprehensive test in a variety of configurations and gain settings
  • Displays diagnostic information down to individual component pins
  • Rugged, hand-held, ergonomically designed case incorporates built-in membrane keypad, 2 x 16 dot matrix alphanumeric LCD and high quality 16 pin ZIF socket
  • Battery operated (4 x AA) with low power design, auto power-down function
  • Mains adapter available
CompactLink
Functional IC test generating software for Compact Professional Range
A PC based software package that allows users to add new devices to the library and create functional tests to suit special applications.
CompactLink uses PremierLink IC Programming (PLIP), a high-level descriptive test programming language optimised for generation of both analogue and digital IC tests programmes.
Connection to PC via RS-232RS-232 or USB (adapter required) / runs with Microsoft XPTm
Man Parts No.Description
CHIPMASTER PROCHIPMASTER PROTESTER, DIGITAL IC
LINEARMASTER PROLINEARMASTER PROTESTER, LINEAR IC
  • 1296492
  • tester
  • ic
  • digital
  • manual
  • user
  • pro
  • linearmaster_pro
  • 23m5485
  • chipmaster_pro
  • abi
  • linearmaster
  • 23m6659
