Test & Tools
Test & Tools
Documents The Rough, Rugged, and Covered in Mud Wishlist!
  • Author Author: dychen
  • Date Created: 10 Jul 2023 8:36 PM Date Created
  • Last Updated Last Updated: 9 Jan 2024 9:50 PM
  • Views 16941 views
  • Likes 10 likes
  • Comments 29 comments
Our Favorite Tools for Engineers in the Wild!
Not all jobs can be done from the comfort of the lab. Engineers often have to venture outdoors and brave the elements, working on devices that are exposed to mud, wind, and sun, or even submerged! This wishlist explores some of the devices that are tough enough to keep up, although bear in mind, most will not survive a plunge into water!
Rough and Rugged Wishlist Giveaway
Answer the question below for a chance to win an Outdoor Rock Speaker!
What's your toughest tool has been through wars in your hands?
We'd love to hear about your roughest projects...and of course, we'd love to see some pictures!
Eight Piece Polished CRV Precision Plier Set
plier set
Buy now
15 Piece Precision Screwdriver Set
precision screwdriver set
Buy now
200mm Vernier Caliper
Mitutoyo Vernier calipers
Buy now
Crimp Tool Set
Multicomp Pro crimp tool kit
Buy now
Gas-powered Soldering Iron
Irodo Gas powered soldering iron
Buy now
Gas-powered Heat Gun
Irodo Gas Powered Heat Gun
Buy now
IP67-Rated Digital Multimeter
Keysight IP67 Digital Multimeter
Buy now
Digital Humidity Meter
Multicomp Pro Digital Humidity Meter
Buy now
Indoor/Outdoor Digital Thermometer
ExTech Digital Thermometer
Buy now
Infrared Thermometer
Fluke Infrared Thermometer
Buy now
IP67-rated LED Strip
TT Electronics Optek LED Strip
Buy now
Waterproof Equipment Case 22.5" x 16.5" x 8.5"
Multicomp Pro Waterproof Weatherproof Equipment Case
Buy now
Waterproof Equipment Case, 10.5"X9.5"X7"
Multicomp Pro Waterproof and Weatherproof Equipment Case
Buy now
Waterproof Tool Case
PEL Tool Case
Buy now
IP67-rated Weatherproof Enclosure for Raspberry Pi, Arduino, Beaglebone, and more.
OpenH.IO IP67 Case for Raspberry Pi, Arduino, Beaglebone
Buy now
Stellar Labs Outdoor Rock Speaker
Buy now
  • durable
  • dustproof
  • outdoor
  • portable
  • rugged
  • weatherproof
  • ip67
  • handheld
  • wishlist
  • gas powered
  • waterproof
  • srutledge
    srutledge over 3 years ago +3
    Hello everyone! I'd like to congratulate the winners of our giveaway: JWx colporteur wolfgangfriedrich dougw If you have not already received your prize, it should be in the mail and on its…
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago in reply to srutledge +2
    Thanks a lot. I am with colporteur on this one. Would be a great improvement for my Halloween 0.5W speaker in the Scare-O-Matic.
  • JWx
    JWx over 3 years ago +1
    multitool of course - mine is somewhat worn-out, but those brand-named seem too good-looking for actual use...
  • wolfgangfriedrich
  • JWx
    JWx over 3 years ago in reply to srutledge
    Thanks a lot! If only tariq.ahmad decides to run planned animal-themed project, I could use this as base of my squirrel repelling system I plan to build to protect my walnut three from excessive theft  Slight smile
  • colporteur
    colporteur over 3 years ago in reply to srutledge
    WooHoo, me thinks it will work with my Halloween animation. Thanks for the gift folks.
  • srutledge
    Hello everyone!
    JWx
    colporteur
    wolfgangfriedrich
    dougw
    If you have not already received your prize, it should be in the mail and on its way to you now. As always, please reach out with any comments, concerns, or customs issues and I'll get back to shortly!
    Thank you all for participating, and good luck next time!
    Sean
    dougw over 3 years ago in reply to rsc
    Nice - it looks a bit like my Boker knife...
  • colporteur
    colporteur over 3 years ago in reply to kmikemoo
    Sweet. I referred to it as a "church-key".
  • kmikemoo
    kmikemoo over 3 years ago
    Thank you, colporteur.  Your Romex stripper reminded me of something I've carried in my pocket since 1982.  It's a flat blade screwdriver and a 1/2" / 13mm wrench.
    Oh... and it also opens up bottles.
  • colporteur
    By my estimation this tool has been in my tool chest since 1988. I call it a Romex wire stripper. I did google search for the name but got a number of hits of other types of wire stripper.
    14/2 electrical wire is inserted into the hole at one end and the tools tooth blade at the other end cuts the outer insulation when pulled back, without damaging the inner conductors. My step father suggested I purchase the tool when I was wiring the basement in my first home. I recall it cost less than $2. It's value far exceeds that. If you ever have cause to run house hold wiring I highly recommend the tool to save installation time. Oh and the skin on knuckles when you have to cut wire installation.
    I've told my son-in-law he can take it from my tool chest when I pass on to the place of perpetual light. Seems I won't need the tool to do wiring there.
    e14 Contributor over 3 years ago
    My trusty Klein crimping /cutting tool. When I first started in AV installations my coworker said "get yourself a good pair of dikes (which is not the accurate term for these but oh well) and if they're Klein's, they'll last forever." I have cut metal, plastic, all kinds of things they weren't meant for, and they keep on trucking. I hit them with some white lithium grease about twice a year and they are simply a pleasure to use. I like using bell crimps rather than wire nuts for most applications so these work great for me.
  • weiwei2
    weiwei2 over 3 years ago
    I opt for drone. It is very useful to provide an bird eye view for doing survey of the surroundings for outdoor engineering project.
    Like surveying for stream and remote water level sensor installed for water management SCADA. i suppose in the future, such monitoring function can even be autonomous and a fleet of drones inspect remote weather station, water level sensor stations in the mountains. It is more efficient than human who need much longer time to cover the inspection by hiking. A drone like below easily cover 5km range and can fly 30 minutes
    shown below is using the drone to survey Mengkuang dam. Of course, other than work, this can be used for outdoor activity like photo taking and path finding
    imagedamimage
    the drone is attached to a phone for easy navigation and control. its camera comes with gimbal with superior image stabilization. It also features a go home function if remote control signal losts.
    This is a 249g drone. It is not 250g because for 250g one need to register with the civil aviation authority. in this phone, we have flown to the highest point which is 120m from where we are standing. Our starting point is roughly at 400m + from sea level.
