Test & Tools
Test & Tools
Documents Is it possible to connect 0-8 mA vibration sensors to a USB PC Data Logger and if so how?
  • Author Author: dsohal
  • Date Created: 6 Oct 2009 9:32 AM Date Created
  • Last Updated Last Updated: 7 Oct 2021 12:37 AM
  • Views 781 views
Yes, you can, if you use an appropriate shunt resistor. The          easiest way to connect the shunt resistor is to use the terminal board          designed for the logger. Order the PP053 ADC-11          terminal board, the PP054 ADC-16          terminal board or the PP310 ADC-20/ADC-24          terminal board.
  • logger
  • connect
  • pc
  • to
  • sensors
  • pico
  • usb
  • and
  • is
  • it
  • data
  • if
  • vibration
  • a
  • how?
  • so
  • ma
  • 0-8
  • possible
