Test & Tools
Test & Tools
Documents I would like display current against time instead of volts against time. Using Ohm's law I can calculate the current from the voltage but I was wondering if there is a way of changing the y-axis ?
  • Author Author: dsohal
  • Date Created: 16 Mar 2010 3:38 PM Date Created
  • Last Updated Last Updated: 7 Oct 2021 3:27 AM
  • Views 716 views
Yes, by using Pico scope 2205 (using Pico scope 6  software), with the "custom  probes" feature in PicoScope. Click the Channel Options button for  the relevant channel, then click the button with three dots to the right of the  word "Probe". This opens the Custom Probes dialog. Click "New Probe" and fill in  the series of dialogs that appears. Ignore all the advanced options, choose  "amperes" as the display unit and "linear equation" as the scaling method, and  enter the desired conversion factor in the "gradient" box. Back in the Channel  Options dialog, select the new probe that you have just created, and you will  then see the vertical axis correctly scaled in milliamps.
  • of
  • current
  • instead
  • against
  • the
  • from
  • y-axis
  • law
  • wondering
  • changing
  • volts
  • there
  • time.
  • way
  • but
  • voltage
  • is
  • calculate
  • display
  • like
  • ohm's
  • time
  • if
  • a
  • would
  • using
  • can
  • i
  • was
