Test & Tools
Test & Tools
Documents Seaward PAT Testers and Kits
  • Author Author: dsohal
  • Date Created: 3 Mar 2011 11:19 AM Date Created
  • Last Updated Last Updated: 7 Oct 2021 8:49 AM
  • Views 619 views
Web link to Seaward PAT testers & Kits
http://www.seaward.co.uk/products/portable-appliance-testing-equipment/pat-tester-kits
Product Filters
header
250V Insulation Resistance Test (8) 3 phase leakage test (1) Battery Operated (7) Downloading/with memory (6) Flash Test (1) Kits (6) Manual (5) Protective Conductor/ Touch Current Test (8) RCD Test (4) True dual voltage (230/110V input/output) (1)
footer
PAT testers reduce the risk of electrical shock by detecting potential safety problems with electrical appliances before they occur.
A wide range of Seaward PAT testers is available‚ from basic pass/fail instruments that carry out fundamental safety checks to more advanced models with comprehensive PAT testing capabilities including some with Bluetooth technology and test data downloading capabilities.
With such a wide variety of electrical testers to choose from‚ the extensive Seaward PAT range meets the electrical safety testing needs of all companies and organisations.
In addition‚ the comprehensive series of test instruments is supported by a full range of PAT accessories for comprehensive portable appliance testing solutions.
To make PAT purchasing decisions more straightforward‚ Seaward has streamlined the selection of portable appliance test equipment by bringing different PAT test elements into distinct product packages that meet different user requirements.
The special Seaward PATBag concept combines hand held PAT testers with a test guide and training DVD alongside a log book for test results and a supply of ready-made electrical safety testing labels.
Special PAT record keeping software options are also provided - with everything contained in a purpose designed carrying bag for maximum portability.
There are 12 products that match your filter criteria
PrimeTest 350
The PrimeTest 350 PAT tester enables fast and efficient portable appliance testing. This handheld battery powered tester stores results and connects wirelessly to results printers and barcode scanners.   View Product
Supernova Elite
The Supernova Elite advanced downloading PAT tester has a comprehensive range of tests including RCD trip time and flash test, as well as dual voltage capability. A test record memory stores up to 5000 PAT testing results. View Product
Europa Plus
The Europa Plus is a portable appliance tester and then some. With its full compliment of tests and dual voltage abilities you can PAT test any appliance right there, right then.   View Product
PrimeTest 250
The handheld PrimeTest 250 PAT tester features all of the electrical safety tests required to meet the IEE Code of Practice including RCD trip time, protective conductor current and touch current. View Product
PrimeTest 100
The PrimeTest 100 is a functional and diverse manual PAT tester. Featuring three operational modes, it is an ideal choice for those looking for an easy to use, electrical safety tester. View Product
PrimeTest 50
The PrimeTest 50 manual PAT tester is battery powered and handheld to allow for fast and efficient testing. A simple range of tests are selected at the push of a button - earthed appliance, double insulated appliance, or mains cord test. View Product
PrimeTest 350 PATSolutions Package
The PrimeTest 350 PAT Tester PATSolutions kit contains everything you need for effective portable appliance testing housed in a rugged toolcase. The included accessories and software really bring the benefits of this advanced tester to life. & View Product
Supernova Elite PATSolutions Package
This Supernova Elite PATSolutions kit includes everything you need to complete the PAT testing process easily and efficiently, from a comprehensive range of tests, to label printing and data management software. View Product
Europa Plus PATSolutions Package
This Europa Plus PATSolutions kit includes everything you need to complete the PAT testing process easily and efficiently. From a comprehensive range of tests, to label printing and data management software. View Product
  • testers
  • and
  • pat
  • seaward
  • kits
