Test & Tools
Test & Tools
Documents GOODWILL SPECTRUM ANALYSER, 3GHZ  GSP-830  ,Farnell o/c 1563802
  • Author Author: dsohal
  • Date Created: 8 Apr 2011 8:10 AM Date Created
  • Last Updated Last Updated: 7 Oct 2021 9:02 AM
  • Views 609 views
Regarding the miss “R” and “S” both words, pls find attached the V1.39 software  to upgrade the GSP-830, and upgarade procedure as attached also.    We expect  the issue should be solved.help to confirm us if the issue could be solved or  not after customer make the version upgrade.
See below up grade procedure file.
Q; The Aux Signal appears to be in  spec (see attached screen dump) reading 100.0039MHz @  -28.1dBm.I updated the firmware as  instructed and the ASCII problem seems to be corrected.
The preamplifier continues to  give an attenuated reading rather than adding 20dB as  intended.
A:
There are probably problems as  below:
1.GAP-802 probably  damage.
2.Please  kindly measure the DC power supply connector to  check whether its output power of DC 9V.
If  the GSP-830  DC power supply didn’t have output the DC 9V voltage, pls let me know for  fix further issue.
7043.V139_101227.zip
imageUpgrade procedure for GSP-830.pdf
  • analyser
  • goodwill
  • 3ghz
  • spectrum
  • gsp-830
  • farnell
  • 1563802
  • o/c
