Test & Tools
Test & Tools
Documents USB driver for window 7_64 bit,for UT2042C,Farnell o/c 1739443  ,Tenma 72-8225,file on use of FET, user manual
  • Author Author: dsohal
  • Date Created: 28 Apr 2011 10:29 AM Date Created
  • Last Updated Last Updated: 7 Oct 2021 9:45 AM
  • Views 1263 views
TENMA - 72-8225 - DIGITAL STORAGE SCOPE, 40MHZ, 2 CH
Manufacturer:
TENMA
Order Code:
1739443
Manufacturer Part No:
72-8225
RoHS :
Description
  • DIGITAL STORAGE SCOPE, 40MHZ, 2 CH
  • Scope Type:Digital
  • Scope Channels:2
  • Bandwidth:40MHz
  • Meter Display Type:LCD
  • Sampling Rate:500MSPS
  • Rise Time:8.7ns
  • Supply Voltage Min:100V
  • Supply Voltage Max:240V
  • External Height:150mm
  • External Width:320mm
  • External Depth:130mm
  • External Length / Height:150mm
  • No. of Channels:2
  • Record Length:1024k
  • Sample Rate:500MS/s
USB driver for window 7_64 bit,for UT2042C,Farnell o/c 1739443  ,Tenma 72-8225, V8.8 is  designed for the Oscilloscope made before Nov21.2008 only afte that, pls use upgrade software V1.00 or V1.01.
File for FET operation, see below.
DSO USB_Driver for WIN7_64bit.zip
Communication & Control Software V1.01.exe.zip
0677.Communication & Control Software V1.01.exe.zip
Communication&Control Software for 72-8225V1.01.exe.zip
image444553.pdf
FFT Operational guidelines.xlsxFFT Operational guidelines.xlsx
imageUT2000_3000Eng_Manual.pdf
  • driver
  • bit
  • of
  • 72-8225
  • on
  • ut2042c
  • window
  • 1739443
  • farnell
  • usb
  • 7_64
  • tenma
  • for
  • use
  • o/c
  • file
  • fet
