Test & Tools
Test & Tools
Documents Fluke 8808A, instruction manual in Polish & English
  • Author Author: dsohal
  • Date Created: 15 Jul 2011 3:55 PM Date Created
  • Last Updated Last Updated: 7 Oct 2021 10:42 AM
  • Views 640 views
Versatile multimeter  for manufacturing, development and service applications
  • 5.5 digit resolution
  • Basic V dc accuracy of 0.015 %
  • Dual display
  • Dedicated dc leakage current measurement
  • 2x4 ohms 4-wire measurement technique
  • Six dedicated buttons for fast access to  instrument setups
  • Hi/Lo limit compare for Pass/Fail testing
The Fluke 8808A multimeter has a broad range of functions,  measuring  volts, ohms and amps with a basic V dc accuracy of 0.015 %. It is   remarkably easy to use, even by unskilled operators, because it makes  the  measurements you perform most often extremely easy and fast to do.
Six setup buttons on the 8808A front panel operate like a  car  radio’s station presets. Simply set up the meter for a common  measurement,  then press shift followed by a setup button (S1 to S6) to  save the setup. Now  each time you perform that measurement, you simply  press the appropriate setup  key. It’s that easy!
The  setup buttons eliminate the need to follow complex work  instruction sheets.  Operators no longer need to press multiple buttons  to set up a measurement  function and range, test limits, or enter other  parameters to make a  measurement.
image8808a___umeng0100.pdf
  • in
  • polish
  • manual
  • instruction
  • 8808a
  • fluke
