Test & Tools
Test & Tools
Documents Software for Tenma 72-7732 for windows7
  • Author Author: SSG_Tech_Support
  • Date Created: 29 Jan 2012 6:54 AM Date Created
  • Last Updated Last Updated: 11 Sep 2024 12:57 PM
  • Views 2340 views
  • Comments 5 comments
File Name :
Tenma 72-7732.zip (including interface software and operating manual)
Support Model :
Tenma 72-7732
Operating Systems:
Microsoft Windows 7 32-bit, 64-bit
Microsoft Windows XP  32-bit, 64-bit
Tenma 72-7732 Windows 7 Software
    Hi!
    Can you share the LabView kit?
    thank
  • camtest
    camtest over 13 years ago
    I've a 72-7732A, and the software works OK on Windows 7/64-bit (as far as it goes).
    However I've been using LabView for quite a few years, and want to do some things with that.
    Has anybody tried this before?
    I hoped it was a simple USB-serial, but it only shows up in the device manager as "USB input device", VID_1A86 / PID_E008.
    This seems to equate to a USB-serial converter from WCH.CN but their website is rather impenetrable for my limited language skills.
    I tried NI's VISA driver wizard, and that made a driver (which stops the supplied software working, but that's not a great loss).
    The VISA interactive control can see the resulting device (as can the device manager) and open a connection to it, but throws an error if I try to do anything.
    MAX can't see it at all, nor can LabView.
    So, I'm hoping somebody else (who knows what they're doing!) has tried this before?
    It works fine now. Thank you!
  • IZ0ABD
    IZ0ABD over 13 years ago
    It correctly works on Windows 7 64 bit.
    When I connect the USB interface to the USB port I see a HID device and the drivers are correctly installed.
    To enable data reading by the software just press and hold down the MAXMIN button (enable SEND data).
    It does not work at all. Nice Blue Screan of Death on my MS Windows 7 32-bit after running executable.
