Test & Tools
Test & Tools
Documents Software for Tenma 72-8720 for windows7, protocol file for automatic test system
  • Author Author: SSG_Tech_Support
  • Date Created: 29 Jan 2012 7:14 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 4:47 AM
  • Views 2796 views
  • Comments 9 comments
File Name :
Tenma 72-8720.zip (including interface software and operating manual)
Support Model :
Tenma 72-8720
Operating Systems:
Microsoft Windows 7 32-bit, 64-bit
Microsoft Windows XP  32-bit, 64-bit
Q:
Product . . . : 1836062 DMM, BENCH, 39999 COUNTS TRMS Manu. Part No : 72-8720 TENMA Question: For the RS232 communication the customer would like to have the exact settings like baud rate, parity and so on. Just having the drivers (as can be found on element 14) installed is not suitable for the customer's setup since this meter is used in an automatic test system and under LabView or Matlab. Could you help out?
A; Please see attached word file for answer ( 72-8720 protocol file)
72-8720 protocol.xls72-8720 protocol.xls
Tenma 72-8720.zip
  • test
  • automatic
  • 72-8720
  • tenma
  • for
  • protocol
  • system
  • windows7
  • file
  • software
  • govindsankar
    govindsankar over 3 years ago
    Hi,
    I understood there is this software. But how do I automate using labview. Is their a programming manual or is labview driver for this. I couldnt find it anywhere. Thank you.
  • dsohal
    dsohal over 8 years ago in reply to daniel.teixeira
    Hi Daniel,
                   I received reply from our supplier as shown below.
    It should be
    no problem to transmit data through USB from Tenma 72-8720 to computers, you
    can copy the computer interface software and protocol from below link.
    unluckily factory hasn’t solution for mobile phone App yet.
    Thank you,
    Devinder Sohal,
    Farnell technical,
  • daniel.teixeira
    daniel.teixeira over 8 years ago
    Just in case anyone has the same hard time as i did to figure out how to integrate the meter into my app, here is a link for the usb chip manufacturer with source code and a demo app:
    https://translate.google.com/translate?hl=en&sl=zh-CN&tl=en&u=http%3A%2F%2Fwww.wch.cn%2Fdownload%2FCH9326EVT_ZIP.html
  • daniel.teixeira
    daniel.teixeira over 8 years ago in reply to dsohal
    Hi dsohal,
    I am interested in this issue. Did you manage to find any documentation on how to get the 72-8720 to start transmitting data through the usb? I noticed that the official application applies some sort of starting procedure but i cannot find out which steps are involved. From my app i can capture the usb data correctly but only when the official app started the connection. Could you help me on this?
    thanks!
  • dsohal
    dsohal over 12 years ago in reply to on7ami
    Hi Jean,
                I have recived reply from supplier, some reason I can not attached pdf file on element 14 ,please can you send me your email address, I can send you reply diect.
    Thank you,
    Devinder Sohal,
    dsohal@farnell.com
  • on7ami
    on7ami over 12 years ago in reply to dsohal
    Hi Sohal,
    What I want to do is the inverse of what you suggest, I want to use the RS232 Output of the DVM the USB functions well but the RS232 do not put any information on the signal lines. I want to use the RS232 because the USB driver needed to use in my own software does not work nice. So I need : or a good USB driver accessible from .NET in c# or to be able to use the RS232.
    With the software provided by Tenma (or UNI-T) the USB works fine but via the RS232 I don't get response as well.
    Greets
    Jean Paul
  • dsohal
    Hi Jean,
                  I do not think you can switch between USB and RS232, due different voltage or you can use RS232 to USB converter, our o/c 175-6306, USB to RS232 converter.
    I have send request to  manufacturer and I let you know, what is their suggestion.
    Thank you,
    Regards,
    Devinder Sohal,
    Farnell technical,
  • on7ami
    Best,
    How can be switched between RS232 and USB? When connecting the USB in combination with the software I can capture my results. When connecting a RS232 cable nothing appears on the pin 2 nor on pin 3 of the Sub-D.
    Greets,
    Jean PAul
    We are currently considering purchasing this DMM for use in an automated test system. However, the provided protocol description seems somewhat lacking.
    Could you elaborate on the data format?
