Test & Tools
Test & Tools
Documents Tektronix Hand hold oscilloscope THS 3000 series , data sheet, video , manual data sheet, video , manual  and other information/*
  • Author Author: dsohal
  • Date Created: 6 Mar 2012 11:32 AM Date Created
  • Last Updated Last Updated: 8 Oct 2021 4:49 AM
  • Views 970 views
THS3000 Series Handheld Oscilloscope
            Portable Performance for Challenging Environments
With four isolated channels and up to 7 hours of battery life, the lightweight THS3000 Handheld Oscilloscope Series enables you to safely make floating or differential measurements on your bench or in the field. Now you can tackle tough environments with the performance you expect from Tektronix – safely and affordably.
  • Data Sheet
  • Manual
Models in the THS3000 Series:
THS3014          100 MHz          2.5 GS/s          10k point          4 Channels
THS3014-TK          100 MHz          2.5 GS/s          10k point          4 Channels
THS3024          200 MHz          5 GS/s          10k point          4 Channels
THS3024-TK          200 MHz          5 GS/s          10k point          4 Channels
  • Features
    Benefits
    Four isolated channelsSafely and easily make 4-channel floating or differential measurements, including 3-phase power measurements.
    10 Kpoints record length per channelCapture more signal information at higher sample rates to clearly see signal details.
    Dedicated front-panel controlsSpend less time learning and more time on your task with easy-to-use front-panel controls.
    Waveform limit testingAutomatically monitor up to four signals and evaluate pass or fail results determined by predefined boundaries.
    Data logging featuresQuickly find signal anomalies by using the TrendPlotTm function or by capturing multiple waveform screens for playback and review
    7 hour batteryWork where you need to with up to 7 hours of continuous battery operation.
    Just 4.8 lbs (2.2 kg)Easily transport from the lab to the field with the lightweight and compact design.
    USB host and USB mini portsQuickly and easily save instrument settings, screenshots, and waveform data onto a flash device or transfer the data directly to a PC.
    Web link for full deatils  http://www.tek.com/datasheet/handheld-oscilloscopes
  • Web link to down load manual  http://www.tek.com/oscilloscope/ths3000-manual/ths3000-series   ( please see below for user manual as pdf form )
  • Virtual tour of product ,web  link http://www.tek.com/oscilloscope/ths3000
  • Probes and accessories  web link  http://www.tek.com/oscilloscope/ths3000
  • Difference between open choice and wave star WSTRO software , see web link http://www.tek.com/support/faqs/what-difference-between-openchoice-desktop-and-wavestar-wstro-software-programs
  • Q; How many screens can be saved on internal memory?
  • A; 100 screens can be saved on internal memory, see user manual "save & recall section".
image3GW_27121_2.pdf
imageTHS3000manual.pdf
  • 3000
  • sheet
  • information
  • series
  • video
  • manual
  • tektronix
  • oscilloscope
  • and
  • Other
  • hold
  • data
  • ths
  • hand
