Wearable Technology
Wearable Technology
Blog Spring Hoodie 5: Everyday I'm Solderin'
Join Wearable Technology to participate - click to join for free!
  • Author Author: brenyc13
  • Date Created: 4 Apr 2015 12:31 PM Date Created
  • Views 1542 views
  • spring_hoodie
  • neopixel
  • soldering
  • Wearables
  • wearable_tech
  • adafruit
brenyc13
brenyc13
4 Apr 2015
A short post on the week’s progress
So. Much. Soldering.
My technique for making the LED flowers  means that in order to connect them together I have to solder a longer bit of wire from each of the four “stem” wires to the next little wires in the sequence. And I need to add additional longer wires for the power and ground that branch out to supply all of the LEDs. In short, I soldered ~70 connections the other day.
Troubleshooting
I really should test as I go along. I’m not sure why I don’t, probably some intuition toward efficiency and batch processing. But what ended up happening is that I finished-up my marathon soldering session to find that only two of my flowers even lit up. After a few frustrated hours, I just replaced two of the LEDs. But I did get a tutorial from my Hunky Assistant on how to use a multimeter and oscilloscope. So at least there’s that.
Flower Arrangement
Then I took a break from the tough stuff and just added oodles of in-fill flowers. Some are nicely sewn. Some are glued. But I like how this is turning out.
Next week will have more of a focus on the code...
    DAB over 11 years ago
    I agree, it is looking awesome.
    You will definitely get attention when you wear it.
  • clem57
    clem57 over 11 years ago in reply to DAB
    She will be a flashy lady! image
