Wireless
Wireless
Blog QiLiCape Progress
  • Author Author: danteo
  • Date Created: 20 Nov 2012 6:53 PM Date Created
  • Views 797 views
QiLiCape Progress
danteo
danteo
20 Nov 2012
Still under construction...
I'm still not decided about a kernel mod for additional power management support,
I kept a place for a small 430g in order to manage the charging options but maybe is not necessary.
The coil will be a Vishay IWAS-4832FF-50 and the battery a 1000mAh LiIon. All stacked.
Searching other coils I found this complete RxTx set for only $9.50 but not Qi compliant called "Wireless Power Supply"
from seeed http://www.seeedstudio.com/depot/wireless-power-supply-p-701.html
http://www.seeedstudio.com/depot/images/product/Wireless%20Power.jpg
  • danteo
    danteo over 13 years ago in reply to lfa555
    Thank you Lars, I choose the Vishay but I will test also the Wuerth coils.
    Dan
  • lfa555
    lfa555 over 13 years ago
    Hi Danteo,
    saw that you are using the RX coil from Vishay. Have you also had a look at the 760308201
    http://de.farnell.com/wurth-elektronik/760308201/wireless-power-charging-spule-10uh/dp/2114372?in_merch=New%20Products
    It is a more compact design
    regards
