Wireless
Wireless
Blog Testing HD Radio
  • Author Author: gervasi
  • Date Created: 19 Jul 2013 11:49 PM Date Created
  • Views 1715 views
  • Comments 6 comments
  • hd_radio
Testing HD Radio
gervasi
gervasi
19 Jul 2013
A few months ago someone asked me where to find an HD radio.  Despite my interest in radio, I had heard of HD but knew almost nothing about it.
When I researched it, I learned that digital broadcasting (as expected) is much more efficient, but no digital standard has been adopted to replace AM/FM broadcast radio.  “HD radio” is the digital standard the US adopted.
HD originally stood for hybrid-digital because the signals are transmitted in parallel with the legacy analog transmissions.  HD is now just the brand name for the standard.  It has never stood for high-definition.
High-performance radio retailer CCrane told me they have plans no to carry an HD radio.  They tried many models and could not find a single receiver that met their standards.  They said, "AM reception is abominable on all of the HD tuners we tested".  When they did carry them the return rate was two to three times the rate for other radios.  This is possibly because the subcarrier that carries HD is 20dB down from the analog carrier, so you need a strong signal to receive HD reliably.
Testing Insignia NS-HDRADimage
I tested the Insignia NS-HDRAD receiver.  It did very well.  There was no noticeable intermodulation from the strong FM stations located near the office.  It detected the HD signal from several stations in my area.
Most stations with HD provide two channels with similar programming.  The WI Public Radio FM station in my area has three choices of digital programming on the same frequency.  Their third subchannel is dedicated to talk programming and had noticeably limited audio bandwidth.  Stations can have several subchannels, but at least one must be at least the same quality as the analog signal .
One nice feature with the Insignia radio is the AUX IN port.  I used it to listen to audio from my MP3 player.
The biggest downside to this radio is it has no AM coverage.  I looked at other HD radios, and many have no AM or analog-only AM.
Another issue is the volume.  I had to turn up the volume near maximum to listen to the low-bandwidth digital station with talk programming.  The same was true when listening to my MP3 player (at its max volume) through the AUX port.
Next Time
Next week I test a JVC KT-HDP1, which does support AM, and tear it down.  It becomes clear that someone needs to design a high-quality AM/FM HD Radio receiver.
    DAB over 13 years ago
    Hi Gervasi,
    I was not aware that they were introducing digital audio on AM and FM channels, but it makes sense.
    The AM and FM bands remain among the last fully exploited frequencies for the modern digital age.
    It would be interesting to compare the digital and analog broadcast to see if the digital encryption improves the music quality, especially in a moving vehicle where you can get more signal reflections and interference.
    I agree, 20db does not sound like a lot of signal to noise support, but I suspect that it was limited by compatibility issues with the analog recievers.
    I also suspect that other industries will begin to lobby for a redo of the channel allocation so that they can bring out new and improved broadcast content in these bands.  It is probably just a matter of time.
    Good post, I like how you keep the awareness up for RF.
    Thanks
    Hi Gervasi,
    Thanks
