Wireless
Wireless
Forum urgent! Does anyone know 26-pin or 40-pin 8255??
  • Subscribers 221 subscribers
  • Views 1730 views
hi, i'm doing a project and need a 26-pin 8255 microprocessor(i'm not sure whether its called "microprocessor") i tried many method but still cannot find it. Does anyone know any information about it!!!?
  • grunnen
    grunnen over 15 years ago
    Maybe you already discovered but this is what I can mention you.
    The Intel 8255 is a Programmable Peripheral Interface: parallel port chip.
    You might find one in old PCs like PC/XT with 8008, 8080A, 8086 or 8088 processors (1986-ish...).
    According to Wikipedia these were also used in Z80 systems.
  • WestfW
    WestfW over 15 years ago
    I don't think the 8255 was ever available except in a 40 pin package (I don't know if ANYTHING was available in a 26 pin package!)  A more modern equivalent is the CMOS version: the 82C55; this is still a very old chip, and  modern vendors (Farnell/Newark included) don't seem to have stock, but some of the vendors with more history in the hobbyist market seem to still have them (both Digikey and JameCo claim to be able to ship immediately.)
    http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_52425_-1
    http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=CP82C55AZ-ND
    DAB over 15 years ago
    The 8255 was indeed a parallel port for Intel and came in a 40 pin DIP package.  Yes I do have some and they may still work.  There was a serial port chip, the 8251 which was 24 pins in the same era.
    There were a bunch of micro-controllers in that era that combined a 8085 MCU with integrated serial I/O and parallel I/O, but most of them were 40 pin packages.  If you can clarify your requirements, I might be able to find you both chips and pinouts.
  • grunnen
    Hi WestfW,
    82C55 has the same functionality?
    If so. Then for dukevam: please check the Farnell site for possible solutions:
    INTERSIL - CP82C55A-5ZCP82C55A-5Z - PERIPHERAL INTERFACE, 82C55, DIP40 - Ordercode: 1018159;
    INTERSIL - CP82C55AZCP82C55AZ - PERIPHERAL INTERFACE, 82C55, DIP40 - Ordercode: 1018158;
    INTERSIL - IP82C55AZIP82C55AZ - IC, PROGRAMMABLE CMOS INTERFACE - Ordercode: 1562050.
    grunnen
    e14 Contributor over 15 years ago in reply to WestfW
    Newark and Farnell both have this part in stock:
    http://www.newark.com/intersil/cp82c55a-5/ic-prog-peripheral-interface-dip/dp/06F3290?whydiditmatch=rel_default&matchedProduct=82C55A-5&matchedProduct=82C55A-5&whydiditmatch=rel_default
    http://uk.farnell.com/jsp/search/results.jsp?N=0&Ntk=gensearch_001&Ntt=82C55A-5&Ntx=mode+matchallpartial&suggestions=false&ref=globalsearch&_requestid=259747&isGoback=false&displaytext=&isRedirect=false
    Hi J, I got this address of the internet, the same site might be useful to you for other stuff.  http://www.datasheetcatalog.org/datasheet/Intel/mXuttts.pdf
    Kevin
