Wireless
Wireless
Forum WiFi (SN8200)
  • Subscribers 221 subscribers
  • Views 976 views
WiFi (SN8200)
I bought a SN8200 Wi-Fi Module to connect my STM32F4 Discovery Board with my smartphone.
I connected the SN8200 and the STM32F4 as it is in the User Manual shown.
Do you have any code examples how to use Wi-Fi direct? Which Commands can I send from the STM32F4 to the SN8200?
  • element14jamie
    element14jamie over 12 years ago
    Hello peter.parker,
    Thank you for posting your question, I will move this to our Wireless area as it is a better fit for you.
    Jamie
  • julian.higginson
    julian.higginson over 12 years ago
    hi peter.parker
    I just had a quick look at the SN8200 user manual/datasheet from murata
    http://www.farnell.com/datasheets/1703117.pdf
    Anyway - I don't see any reference to wifi direct in this datasheet.
    Wifi direct is a fundamental extension of the capabilities of basic wifi, and if the controller doesn't have it as a feature, you're not able to drive it using application level commands to do the equivalent.
    http://www.wi-fi.org/discover-and-learn/wi-fi-direct
    That said - you may be able to set it up as a standard access point/hotspot for your smartphone to connect to, and still have communication between smartphone and your STM32.
    In that case I'd be looking for a "serial bridge" application example.....  that should also include instructions/examples for connecting to it from the client side, too.
  • jshroff
    jshroff over 12 years ago in reply to julian.higginson
    Hi Julian,
    I had the same question about WiFi direct - looking at the Broadcom site (since the Murata doc's mention that the SN8200 uses the WICED SDK) it mentions WiFi direct as being supported so I would assume the core chipset does support WiFi direct - the question than is how to access that capability?
    What are the support channels for this module to get an answer from the supplier?
    Jay
  • andru
    andru over 12 years ago in reply to jshroff
    Excuse me. Recently I bought Discover WiFi module with SN8200, but I didn't find the letter with access code to download software examples. Can you give me the link with this examples or access code, please?
