Wireless
Wireless
Forum New round Transmitter Coils from Würth Elektronik
  • Subscribers 222 subscribers
  • Views 1046 views
  • texas-instruments
  • texas
  • wurth_electronics
  • würth
  • a11
  • qi
  • wireless
  • wireless-power
  • power
  • a10
lfa555
lfa555 over 12 years ago
Dear Wireless Power Challenge Participants,
effective immediately Würth Elektronik's has released for you our new brand new round shaped wireless charging coils for the QI A10 and A11 standard. I know you have requested such more space saving coils before. The stock is available at We and you can order the coils via samples from Christian DeFeo.
50mm diameter Transmitters:
WE-WPCC Wireless Power Charging Transmitter Coil - Product Catalog Passive Components
Those coils are right now exclusively available for you and within the next 2-3 weeks they will be also available at Farnell to buy.
Happy Designing and Crafting!
regards
Lars
  • hlipka
    hlipka over 12 years ago
    Oh no, more measurements to be made image
  • ipv1
    ipv1 over 12 years ago
    Can we use these coils with the existing transmitter circuit or do we need to redesign?
  • lfa555
    lfa555 over 12 years ago in reply to ipv1
    Hi there,
    good question Inderpreet Singh
    yes sure. 760308111 is used on the transmitter of the Kit and you can rplace it with the round version 760308100111. So no re-design necessary.
    @ Hendrik, sorry for that, but isn't there a german saying, which describes it well: Nach dem Spiel ist vor dem Spiel!? :-)
    regards
    Lars
  • hlipka
    hlipka over 12 years ago in reply to ipv1
    I think as long as the inductance matches the one from the existing coil (6.3µH) you should be fine. Anything else might mean to replace the capacitors on the transmitter board to get a proper matching.
    My biggest concern would be how to remove the existing coil from the transmitter board without destroying it (to be able to use it again).
    I think I will try some of the new coils, just the provea another german saying: 'wer misst misst mist' image
    (and maybe I can get a bigger transmission range with them as well...)
    mcb1 over 12 years ago in reply to hlipka
    Hendrik
    I seem to recall a TI datasheet which (from memory) suggested the distance is proportional to the size of the coil.
    ie the bigger the coil the greater the distance and still maintain acceptable coupling.
    I'll do some digging and see if I can find it.
    I don't mind you doing the testing ..image
    mark
