Wireless
Wireless
Forum 868 Mhz Wifi RF module for MCZ Pellet stove
  • Answers 3 answers
  • Subscribers 221 subscribers
  • Views 3842 views
cubitus
cubitus over 7 years ago
Hi all,
I have a Google Home that I'd like to control my MCZ Pellet stove by voice command.
I have a remote for the stove that works at 868 Mhz, so I need a RF bridge that can manage that.
I've tried to google for such a device, but I can't find it, so I'm searching for en expert that can guide me. I'm a total novice on the subject.
I've found this device here on Farnell, but I'm unsure if it will work. My plan was to stick the USB part in my router and use Ifttt to control the command.
USB Gateway, Wireless Transceiver Module, 868 Mhz
regards
Pierre
  • Gough Lui
    Gough Lui over 7 years ago +1 suggested
    Life is much more complicated than that and unless your stove uses the Enocean protocol and you run a PC with the Enocean software, the module you suggest can not work. The truth is that manufacturers…
  • Gough Lui
    0 Gough Lui over 7 years ago
    The truth is that manufacturers use all different sorts of control mechanisms at these frequency and do not usually document it. To make something work wolllikely need you to open things up, investigate the encoding of signals on the air (e.g. by using an SDR radio), reverse engineer the commands themselves and re-implement on a microcontroller and transceiver chip combination. Then you need to get the combination on the network (securely) in a way that Google Home can talk to - you don't want someone random on the internet messing around with it.
    It's always easier if it is a model someone else has done the hard work for, but as someone who has reverse engineered a number of devices, it is time consuming and does require some level of expertise.
    - Gough
  • cubitus
    0 cubitus over 7 years ago in reply to Gough Lui
    Thank you for your answer.
    I had a feeling it was to complicated for me.
    I have to accept the fact that I continue to use the remote.
    Thanx and have a good day
  • pstr207
    0 pstr207 over 7 years ago
    Hi Pierre,
    I stumbled upon a similar issue, although it was not a stove in my case. I could not find the 868 Mhz - wifi bridge for Google Home.
    The idea just flashed through my head this evening. May this be helpful: https://www.youtube.com/watch?v=8h5ZCviPSvc
    I wanted to make a c# app that would control 868 transceiver via USB that would control garage doors and automatic garden gate.
    So I got one from China, and I also acquired sub gigahertz radio spectrum analyzer and decoder from France.
    In the end, the simplest solution is the best image Cheap universal programmable 868 remote can do the job and can be controlled by another potential-less relay (by soldering two wires to two contacts that are switched by pressing the button manually). That relay can be then operated by other devices, services...
    Even in the case of floating-code remotes is the situation same. You can in most cases pay for another remote from manufacturer of the product (car, home alarm,...) and gut one out like this image
    BR,
    Patrik
  • colporteur
    0 colporteur over 7 years ago
    I understand your motivation but will your insurance cover your loss if a fire in the stove was the cause? Knowing insurance companies, they would love to discover a modification that gave them a way out of having to pay.
    Sean
  • pstr207
    0 pstr207 over 7 years ago in reply to colporteur
    Hi Sean, good point. That would definitely be a pickle in case someone left any flammable items on the hob (Kochfeld in German), and this person or somebody else would activate the relay for the hob by voice from a remote location and unintentionally caused the fire. A stove (hob and oven as well) is not an excellent example for DIY remote solution, but it's doable.
    (There are lots of ovens controllable over wifi by proprietary clouds, and some of them are interoperable with Google Home - no risk of non-fulfillment from insurance companies***)
    May my solution then be useful to anyone else who does not control devices with a possibility of causing a fire. (FI - anyone who has a piece of appropriate equipment can capture and reuse the non-floating code of your garage's door 315/433/868 MHz wireless communication). Meaning that this solution may be to some extent useful in this or other less risky situations.
    *** well I bet there are lots of disclaimers, including my Bosch oven.
    BR, Patrik Strakoš
  • sutachi
    0 sutachi over 6 years ago in reply to pstr207
    Hi i have this problem,if you can give to me the a nswer to this remote my mail sutachi@gmail.com
