Wireless
Wireless
Forum Looking for RF coaxial connector, APC 7mm
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 222 subscribers
  • Views 2830 views
Hi everyone!
I'm a newcomer and I'm a little bit desperate looking for a special coaxial connector.
I'm designing and building a coaxial tube for a testing scattering parameters in a DUT.
I found the APC7 (Amphenol Precision Connector 7mm, sexless, BW 18GHz), which fits very well in my design.
And they're common in the test and measurement field, in VNA calibration kits, for instance, because of the low reflections.
The important mechanical, and, I guess, rare feature is that the inner conductor is threaded
(on the side connecting the cable, or in my case a rigid metal rod).
Specifically, its a bead contact with the cable side threaded to mate with a coaxial rigid airline.
But, I had problems in purchase it from several vendors. So, my questions are:
* Do you know any vendor or reseller from which I could get this APC7 (few quantity, 2-4 units)?
* Do you know any connector (in principle reaching 18GHz) which has a threaded inner conductor, like APC7?
I've inserted a link to the Amphenol RF web page where you can find the specs and drawings of the APC7 among others.
http://www.amphenolrf.com/products/precision.asp?N=0&sid=4B203A005D56617F&#specs7
I hope that I have expressed my problem clearly,
and many thanks in advance for your help.
Juanjo Garcia
EE at IFIC (Valencia, Spain)
  • wendydu
    0 wendydu over 16 years ago
    Unfortunately, we can’t find any APC-7 connector on our Newark and Farnell web site. This kind of connector is not very common, so maybe you can use some adaptor to convert APC-7 to another type of connector such as SMA.
    http://www.newark.com/agilent-technologies/11533a/coaxial-adapter-apc-7-to-sma-male/dp/99K4718 this is an APC-7 to SMA adaptor.
  • andy
    0 andy over 16 years ago
    Hi Juanjo,
    I will make enquiries for you. How quickly do you need them?
    rgs
    andy
    0 e14 Contributor over 16 years ago in reply to andy
    Hi Andy,
    many thanks for your offer!!
    Sorry I could not anwer to you before, but the day before you write my son was born and I was really busy!!
    About how quickly I need it... I would say until middle of January. I'm still looking for it, but if I or you don't find it
    I will try to change my coax setup design.
    Moreover, if you could think or find any connector with a threaded terminal (in the inner side of the connector, ie, the cable side),
    instead of classical solder or crimped terminal, it will be also a solution. Unfortunately, I guess this is not very usual too.
    Best wishes and happy new year,
    Juanjo
    0 e14 Contributor over 16 years ago in reply to wendydu
    Hi wendydu,
    many thanks for your message and the proposal, but in fact I'm using this adaptor to convert from APC7 to SMA.
    The point is that I need to add two ports to my coax setup and the most suitable connector for that, in principle, is the APC7 connector with threaded center conductor terminal in the cable side (in my coax setup the cable center conductor would be a brass rigid barrel).
    So, once I have my setup with this APC7 ports, I use the APC7-SMA adaptor to be able to use standard SMA semirigid cables connected to my coax setup.
    Again many thanks and happy new year,
    Juanjo.
    0 e14 Contributor over 16 years ago in reply to e14 Contributor
    I have a small manufacturer in mind for your APC 7MM. Ask for Mike Brewer. http://www.connectronicsinc.com/
    Many Thanks add925!
    I'll contact with Mike Brewer... small light at the end of the tunnel! image
    Best wishes,
    Juanjo
  • koh
    0 koh over 16 years ago
    Hi Juanjo,
    Are you looking for Amphenol number: 131-91050?
    If it is, I think newark does carry it. Newark: 51M2690
    0 e14 Contributor over 16 years ago in reply to koh
    Hi Koh,
    Yes, it is!
    I'll check it.
    Thank you so much and happy new year.
    Juanjo.
    Hi Koh,
    I haven't found it with the Newark ref number you gave to me: 51M2690.
    Is it right? Do you have the link to this Newark component?
    Maybe this part is not there anymore.
    Cheers
    Juanjo
  • koh
    0 koh over 16 years ago in reply to e14 Contributor
    Hi Juanjo,
    Happy New Year to you as well!
    Perhaps, you may want to email newark
    http://www.newark.com/jsp/bespoke/bespoke2.jsp?bespokepage=newark/en_US/custsrv/index.jsp
