Wireless
Wireless
Forum Help to build a wireless beacon!
  • Subscribers 220 subscribers
  • Views 859 views
I am a not an engineer but I have a product idea which I would like to build that involves the idea of a wireless beacon. I am not sure if there are engineers (for hire) or companies that can create a product based on an idea you have to build it? Would appreciate any recommendations.
Meanwhile, the idea I have is for a small (lighter / pager) size wireless beacon that must be run on a battery and is able to connect to a network (ie. phone or pager) independently upon power on.
All help will be greatly appreciated.
  • robotonics
    0 robotonics over 14 years ago
    Sounds interesting, what sort of range did you have in mind for transmission, what sort of message are you intending to transmit? I am happy to help with initial research and have the resources to build a prototype if you wish...image
    0 e14 Contributor over 14 years ago in reply to robotonics
    Hi David, I am not sure. I would presume it would need to be detectable / communicate through the existing network built. Kinda like how ipad / iphone has the locate your phone function through 3G or wifi except this is a persistent beacon that will never shut down. so whoever has the beacon on hand is locatable. Is it possible?
  • Catwell
    0 Catwell over 14 years ago
    Beacon,
    Can you explain how this device would be used? The requirements for the project would be helpful too.
    Cabe
  • robotonics
    0 robotonics over 14 years ago in reply to e14 Contributor
    Hi, Yes it is possible!...In fact there are many products out there that 'do something similar'...For instance there is SPOT Connect a device which you can use to send an SOS by GPRS every 5 minutes or connect to social network sites from practically anywhere in the world. The device can also connect to any bluetooth device such as a smartphone.
    As Cabe said the requirements will help us to advise you further, as a designer I would be looking at a small low power GPS/GPRS/Bluetooth module with a microcontroller....maybe...
