Wireless
Wireless
Forum wifi signal booster / antenna type
  • Subscribers 215 subscribers
  • Views 1472 views
  • wifi
sivaguru
sivaguru over 3 years ago
Hello Everyone!!
I am so curious to know whether there are readily available Wi-FI signal booster for one of my project.
Idea & Use case is to enhance the signal strength from AP to STA with thick wall behind the AP and before STA. Would be great if anyone could point to any MUMIMO kind of antenna solution or a signal booster kind of product.
i am using wroom esp 32 development board (works only 2.4Ghz)
    shabaz over 3 years ago +2
    Probably one reason no one is commenting, is because you seem to have made a conclusion that you need a new antenna or signal booster, when it's far from clear that this is the case. Engineers don't like…
  • robogary
    robogary over 3 years ago +1
    Sorry for the dumb question, why don't standard home wifi boosters work for you ?
    0 shabaz over 3 years ago
    Probably one reason no one is commenting, is because you seem to have made a conclusion that you need a new antenna or signal booster, when it's far from clear that this is the case. Engineers don't like patching stuff on top of possibly incorrect initial conclusions by the (let's say) "client"!
    If the signal currently is so weak through a wall, then higher power (through signal booster or antenna) isn't likely to make as much of an improvement as one might think.
    There are legal issues too. If you've already configured the ESP32 to transmit at the most power that is supported, then you shouldn't boost the power.
    Some (better) options are to simply move the ESP32 (extend it with wires if you must, and deal with that hardware-wise in case the wire lengths cannot trivially be extended for signal integrity reasons), or move or add an access point closer to the ESP32.
  • robogary
    0 robogary over 3 years ago
  • BigG
    0 BigG over 3 years ago in reply to robogary
    Exactly. I was going to suggest the same. Most routers these days allow for multiple access points that enable mesh capability. I believe TP-Link, Google, and I'm sure there are many others, which have off-the-shelf solutions. Usually involves an integrated WiFi plug socket that you plug into your wall socket around the house and this acts as a meshed bridging network. Then it all takes care of itself and your ESP32 dev board can be moved about the premises without bother.
