Wireless
Wireless
Forum Weather Radio
  • Replies 15 replies
  • Subscribers 220 subscribers
  • Views 3891 views
Weather Radio
scottiebabe
scottiebabe over 2 years ago
In north America there are several government agency that broadcast weather forecasts and reports in the VHF band.
https://en.wikipedia.org/wiki/Weather_radio
The closest broadcast station to me, transmits on 162.55 MHz as measured with my TinySA
The broadcast is narrow-band FM with 5 kHz of deviation:
Not many consumer products tune and receive weather radio.
How about modifying an existing FM radio to receive weather radio.
I have one of these low cost AM/FM radio solder kits: https://goughlui.com/2016/09/07/project-paeansonic-cf210sp-cd9088cd7642-amfm-radio-kit/
Its based on the clone of a modern version of the original TDA7000
This app note provides the theory of operation: https://www.cool386.com/tda7000/AN192.PDF
For narrow-band FM one should reduce the IF frequency to ~5 kHz (to improve the sensitivity of the FM quadrature demodulator) and reduce the IF bandwidth to reduce noise and improve selectivity.
In my case, I scaled up the IF capacitors by a factor of 10 ( or close enough I didn't have all the exact values)
I also replaced L1 on the input BPF with a hand wound 45 nH inductor.
For now I am using a TinySA as a local oscillator programed to synthesize an LO at a 7 kHz offset (162.453 MHz).
Eventually I will use an Si5351 as the local oscillator.
Its alive!
Play this audio clip
  • scottiebabe
    scottiebabe over 2 years ago +8
    FM quadrature detectors date back to the vacuum tube days, https://www.rfcafe.com/references/electronics-world/quadrature-fm-detectors-electronics-world-december-1959.htm The quadrature component…
  • scottiebabe
    scottiebabe over 2 years ago +7
    The clones have arrived The break board is a clone of the Adafruit board A different clone yet again here: https://github.com/kholia/Si5351-Module-Clone-TCXO The synth IC is a clone of the Skyworks…
  • scottiebabe
    scottiebabe over 2 years ago +4
    Still waiting for my Si5351 module... I believe they will be fitted with the MS5351M clone https://qrp-labs.com/synth/ms5351m.html A+ product photo, I rarely see wire wrapping in the wild
  • scottiebabe
  • kmikemoo
    kmikemoo over 2 years ago
    scottiebabe This is a fantastic project.  I love it.
  • battlecoder
    battlecoder over 2 years ago
    I love everything about this project!
  • phoenixcomm
    phoenixcomm over 2 years ago
     scottiebabe  Oh, girl snap!! 10 pints for you very neat!!!! ~~ Cris Harrison  Also bragging rights! PS, love the math!!
  • scottiebabe
    The clones have arrived Alien
    The synth IC is a clone of the Skyworks 5351
    https://qrp-labs.com/images/synth/ms5351m.pdf
    The EVB appears to work okay...
    Though the synth is off by about +110 PPM, which is a tad higher than I would expect. It could be the AT crystal they fitted requires a load capacitance greater than what the chip can provide (a max of 10pF). It is what it is, for the price I can't really complain.
    • Vote Up +7 Vote Down
