Wireless
Wireless
Forum Weather Radio
  • Replies 15 replies
  • Subscribers 220 subscribers
  • Views 4048 views
Weather Radio
scottiebabe
scottiebabe over 2 years ago
In north America there are several government agency that broadcast weather forecasts and reports in the VHF band.
https://en.wikipedia.org/wiki/Weather_radio
The closest broadcast station to me, transmits on 162.55 MHz as measured with my TinySA
The broadcast is narrow-band FM with 5 kHz of deviation:
Not many consumer products tune and receive weather radio.
How about modifying an existing FM radio to receive weather radio.
I have one of these low cost AM/FM radio solder kits: https://goughlui.com/2016/09/07/project-paeansonic-cf210sp-cd9088cd7642-amfm-radio-kit/
Its based on the clone of a modern version of the original TDA7000
This app note provides the theory of operation: https://www.cool386.com/tda7000/AN192.PDF
For narrow-band FM one should reduce the IF frequency to ~5 kHz (to improve the sensitivity of the FM quadrature demodulator) and reduce the IF bandwidth to reduce noise and improve selectivity.
In my case, I scaled up the IF capacitors by a factor of 10 ( or close enough I didn't have all the exact values)
I also replaced L1 on the input BPF with a hand wound 45 nH inductor.
For now I am using a TinySA as a local oscillator programed to synthesize an LO at a 7 kHz offset (162.453 MHz).
Eventually I will use an Si5351 as the local oscillator.
Its alive!
Play this audio clip
  • scottiebabe
    scottiebabe over 2 years ago +8
    FM quadrature detectors date back to the vacuum tube days, https://www.rfcafe.com/references/electronics-world/quadrature-fm-detectors-electronics-world-december-1959.htm The quadrature component…
  • scottiebabe
    scottiebabe over 2 years ago +7
    The clones have arrived The break board is a clone of the Adafruit board A different clone yet again here: https://github.com/kholia/Si5351-Module-Clone-TCXO The synth IC is a clone of the Skyworks…
  • scottiebabe
    scottiebabe over 2 years ago +4
    Still waiting for my Si5351 module... I believe they will be fitted with the MS5351M clone https://qrp-labs.com/synth/ms5351m.html A+ product photo, I rarely see wire wrapping in the wild
  • rsjawale24
    rsjawale24 over 2 years ago
    Interesting!
    dougw over 2 years ago
    Cool project.
    I will have to dig out my multiband radio and check those channels out.
  • scottiebabe
    The quadrature component was often developed with an LC tank circuit,
    https://www.nisshinbo-microdevices.co.jp/en/pdf/datasheet/NJM14570_E.pdf
    The TDA7000 is interesting in that it forgoes the magnetics for an active all-pass RC filter to develop a 90' phase shifted signal
    A simplified spice simulation could be the following:
    The all-pass filter provides a 90' phase *** at 70 kHz
    When the IF and 90' phases shifted copy are multiplied together, the original AF signal emerges
    An FFT shows the original 6 kHz AF tone:
    If you filter out the two times IF products, all that remains is the desired AF signal
    • Vote Up +8 Vote Down
  • scottiebabe
    scottiebabe over 2 years ago in reply to dougw
    Thanks! Many handheld radios or an SDR can tune to that VHF band. Now I have a pocket weather radio...
  • colporteur
    colporteur over 2 years ago in reply to scottiebabe
    Oooh the glass transistor!
  • scottiebabe
    The more you know Dizzy
    https://publications.gc.ca/collections/collection_2010/ec/En56-228-2010-eng.pdf
    Here is what my RTL-SDR sounds like
  • rsjawale24
    rsjawale24 over 2 years ago in reply to scottiebabe
    I wonder if the EU also has a similar broadcast.
  • javagoza
    javagoza over 2 years ago in reply to rsjawale24
    Here is some information:
    European VHF Broadcasts - Franks-Weather - The Weather Window (mailasail.com)
  • robogary
    robogary over 2 years ago
    scottiebabe - great project. If you get your amateur radio license, a 2m transceiver usually has the weather stations available :-)
    DAB over 2 years ago
    Great idea.
    A friend gave me a weather radio, I just have not made the time to check it out.
    Thanks for the push.
