Wireless
Wireless
Forum Do you have experience on connecting a Sub-1GHz transceiver to public TV antenna?
  • Replies 24 replies
  • Subscribers 215 subscribers
  • Views 3808 views
  • ISM band Sub-1GHz
HKPhysicist
HKPhysicist over 1 year ago
Dear RF Engineers and Applied Physicists,
What are your experiences on connecting a Sub-1GHz transceiver to a public TV antenna?  Thinking
Since I live in a very dense city with skyscrapers, I cannot set up my own antenna outside my building.  Then, I want to wire my own SMA Male to TV Male Plug coaxial cable.  This will connect my Sub-1GHz transmitter directly to my building`s public TV antenna.
The next step is to connect my ISM band Sub-1GHz transmitter to test a receiver several hundred metres to 1km away.
Who have experience on this?  What else should I do to improve the transmission or communication?  I guess a high quality Element14 MultiComp coaxial cable can serve well.  Satellite
Thanks for your opinions.  Nerd
    shabaz over 1 year ago in reply to HKPhysicist +2
    "I will use my building's public antenna." "I have never seen our public antenna. We cannot access our roof." I don't think you understand; if you still mean the TV antenna, it's not a public "anyone…
  • JWx
    JWx over 1 year ago +1
    In my country many TV antennas are advertised as including LTE filters (probably strong cellular signal is disrupting TV signal). Other points to consider: building's public antenna installation can…
    shabaz over 1 year ago +1
    It might be good to take a step back. It could be worth mocking up something, like a quick tryout, to see what issues there could be, if you're new to this. For example, you might find that the performance…
  • JWx
    JWx over 1 year ago
    Other points to consider: building's public antenna installation can be one-directional, strong signal from the modem probably can ruin TV reception for the whole building (it could be many times stronger than signal received) and the problem with the impedance: celluar antenna is probably 50Ohm while TV cable/antena would be 75Ohm
  • HKPhysicist
    HKPhysicist over 1 year ago in reply to JWx
    Thanks for your valuable opinions.
    It seems that I have to hang a large RF antenna outside my room when testing, in order not to interfere with neighbours. Satellite Nerd
  • anniel747
    anniel747 over 1 year ago in reply to HKPhysicist
    [deleted]
  • HKPhysicist
    HKPhysicist over 1 year ago in reply to anniel747
    Mine is a LTE Cat M1, but the exact band is not very clear.  Every country has her own band,
  • acdc90
    acdc90 over 1 year ago
    look at this for frequency of phone
    then possibly use a vertical dipole to add to phone
    instead of tv yagi (which has box set up for recieving )
    https://en.wikipedia.org/wiki/GSM_frequency_bands#GSM_frequency_usage_around_the_world
    For example, you might find that the performance from a modem, is already as good as it is for your mobile phone. Maybe any bottlenecks are less to do with the antenna.
    Once you've gathered some information, then it's best to spend time to design the overall solution first, before getting into this.
    What if your solution needs two modems, will you attach a second TV antenna? On second pole on the building? As you can see, just that slight requirement (sure it's hypothetical, I'm using it as an example) would then render the idea impractical now regardless of the technical concerns of your antenna and cable (of which there are for sure concerns; none of that will be ideal unfortunately). By the way, you can buy antennas (either indoor or outdoor) designed for cellular use.
    If you're designing all this from scratch, then if it were me, I'd try if possible, as part of the overall design, to locate such things at a suitable position and then run low-cost cable (e.g. cat5, it's less than $1 per meter) all the way to where you want to locate anything else (if you're not say using wireless; I have no idea what your solution is going to look like). There may be reasons not to do that, but it would at least be worth considering (if you have not already ruled it out), since there's a chance it would be more practical. But definitely worth a quick experiment first I think; because I think you're unsure what will work at all, if you're currently considering TV antennas.
  • anniel747
    [deleted]
  • anniel747
    anniel747 over 1 year ago in reply to shabaz
    [deleted]
  • HKPhysicist
    It is because my LTE CAT M1 modem has difficulty in sending data, but I have solved this by orientation.
    Now, the next test is my new Sub-1GHz transceiver.  I want to do a communication test over half to one km away.  So I need an antenna standing high enough.
  • anniel747
    You will certainly need an antenna tuner.
