Wireless
Wireless
Forum Do you have experience on connecting a Sub-1GHz transceiver to public TV antenna?
  • Replies 24 replies
  • Subscribers 215 subscribers
  • Views 3809 views
  • ISM band Sub-1GHz
HKPhysicist
HKPhysicist over 1 year ago
Dear RF Engineers and Applied Physicists,
What are your experiences on connecting a Sub-1GHz transceiver to a public TV antenna?  Thinking
Since I live in a very dense city with skyscrapers, I cannot set up my own antenna outside my building.  Then, I want to wire my own SMA Male to TV Male Plug coaxial cable.  This will connect my Sub-1GHz transmitter directly to my building`s public TV antenna.
The next step is to connect my ISM band Sub-1GHz transmitter to test a receiver several hundred metres to 1km away.
Who have experience on this?  What else should I do to improve the transmission or communication?  I guess a high quality Element14 MultiComp coaxial cable can serve well.  Satellite
Thanks for your opinions.  Nerd
    shabaz over 1 year ago in reply to HKPhysicist +2
    "I will use my building's public antenna." "I have never seen our public antenna. We cannot access our roof." I don't think you understand; if you still mean the TV antenna, it's not a public "anyone…
  • JWx
    JWx over 1 year ago +1
    In my country many TV antennas are advertised as including LTE filters (probably strong cellular signal is disrupting TV signal). Other points to consider: building's public antenna installation can…
    shabaz over 1 year ago +1
    It might be good to take a step back. It could be worth mocking up something, like a quick tryout, to see what issues there could be, if you're new to this. For example, you might find that the performance…
  • HKPhysicist
    HKPhysicist over 1 year ago in reply to shabaz
    Thanks for your valuable opinion.
    I have solved the LTE CAT M1 modem problem by simply orienting its location around my home.  Signal strength reported by my laptop Network Manager is about 85%.
    My next test is to set up an ISM band Sub-1GHz antenna to connect to my Sub 1GHz transceiver which will then talk with my receiver half to one km away.
    This is my first field RF project, very exciting!  Blush
    I will use my building's public antenna.  As my target is civil ISM band under 20dbm radio power, I do not violate any radio rule.
  • HKPhysicist
    HKPhysicist over 1 year ago in reply to anniel747
    Nice.
    Could you show me similar product on Element 14?  Satellite
  • anniel747
    anniel747 over 1 year ago in reply to HKPhysicist
    [deleted]
  • HKPhysicist
    My new antenna is 10-12dbi, 9in tall and 3in in diameter, a huge antenna.
  • HKPhysicist
    So I have to use 50 Ohm coaxial cable, right?  They are quite expensive - 2 pounds per meter.
    https://hk.element14.com/huber-suhner/enviroflex-b58/coaxial-cable-rg58-50-ohm-per/dp/2817372
  • anniel747
    [deleted]
  • HKPhysicist
    Ok, thanks for your opinions.
    I am going to shop an antenna impedance tuner or solder one for my self.
    I've found this post very informative.
    www.ad5gg.com/.../
    I don't think you understand; if you still mean the TV antenna, it's not a public "anyone can transmit" kind of thing. There's some electronics in-between the antenna and the end that you have access to. That electronics is there for amplification in one direction, for a particular frequency range. The electronics also renders it no good for transmit. And, as several people have mentioned, a TV antenna and its typical cable would be no good for LTE or any ISM band.
  • HKPhysicist
    Bad news.  Public antenna is for receiving only.
    Then, I have to set up my own antenna for testing. Upside down
  • BigG
    BigG over 1 year ago in reply to HKPhysicist
    An antenna doesn't care whether its transmitting or receiving. They're just a cleverly spaced strip of conductive material. Essentially, antennas are designed to operate at specific frequencies. This means the length of the antenna has to match the wavelength. So have you confirmed whether the TV antenna is suitably matched to your desired transmit/receive frequency. Otherwise you will struggle to achieve the desired transmit distances, no matter the power.
