Wireless
Wireless
Forum Do you have experience on connecting a Sub-1GHz transceiver to public TV antenna?
  • Replies 24 replies
  • Subscribers 215 subscribers
  • Views 3627 views
  • ISM band Sub-1GHz
HKPhysicist
HKPhysicist over 1 year ago
Dear RF Engineers and Applied Physicists,
What are your experiences on connecting a Sub-1GHz transceiver to a public TV antenna?  Thinking
Since I live in a very dense city with skyscrapers, I cannot set up my own antenna outside my building.  Then, I want to wire my own SMA Male to TV Male Plug coaxial cable.  This will connect my Sub-1GHz transmitter directly to my building`s public TV antenna.
The next step is to connect my ISM band Sub-1GHz transmitter to test a receiver several hundred metres to 1km away.
Who have experience on this?  What else should I do to improve the transmission or communication?  I guess a high quality Element14 MultiComp coaxial cable can serve well.  Satellite
Thanks for your opinions.  Nerd
    shabaz over 1 year ago in reply to HKPhysicist +2
    "I will use my building's public antenna." "I have never seen our public antenna. We cannot access our roof." I don't think you understand; if you still mean the TV antenna, it's not a public "anyone…
  • JWx
    JWx over 1 year ago +1
    In my country many TV antennas are advertised as including LTE filters (probably strong cellular signal is disrupting TV signal). Other points to consider: building's public antenna installation can…
    shabaz over 1 year ago +1
    It might be good to take a step back. It could be worth mocking up something, like a quick tryout, to see what issues there could be, if you're new to this. For example, you might find that the performance…
  • HKPhysicist
    HKPhysicist over 1 year ago in reply to BigG
    Nowadays, TV is UHF range (around 400Mz) with digital transmission.
    My target wireless connection target is an ISM band at 920MHz.Satellite
    That is why I want to use my building`s public antenna.
  • BigG
    BigG over 1 year ago in reply to HKPhysicist
    Unfortunately the antenna lengths required for the two frequencies aren't compatible - a 2cm difference is big for RF. According to omnicalculator.com dipole calculator (which gives a reasonable approximation and thus useful for comparison), the wavelengths don't match very well. As such it's unlikely to work at all, or at best you'll only achieve quite short TX distances.
  • COMPACT
    COMPACT over 1 year ago
    Make sure you’re adhering to the regulations to ensure the safety of yourself and others (even on the ISM bands).
  • anneranch
    anneranch over 1 year ago in reply to COMPACT
    From the original description - you are building a repeater - receive a signal and re-transit it.
    Hence you have to have means  to "receive signal" via receiving antenna and then means to re-transmit the signal  via
    "transmit  antenna".  Both antennas must be designed for specific frequency and desired "directionality" etc.
    The actual "repeater" hardware is your choice. In  general  RF output power in determining factor etc.
