Wireless
Wireless
Forum RF ESD protection
  • Replies 11 replies
  • Subscribers 221 subscribers
  • Views 4281 views
RF ESD protection
nicoloquinte
nicoloquinte over 8 years ago
I'm entering the beautiful world of RF design, and after looking into the documentation of the ublox NEO-6M module and saw this:
So because i know that my antenna is absolutely perfect (that isn't true but i'm proud of my qfh garbage)
I need to go with the inductance method since some manufacturers are saying that I should not go with a TVS because that's doing Bad things to the signal :
https://www.murata.com/products/emc/esd/sol_antenna_noise
So Do someone have any idea about how I can calculate the inductance
(BTW i wont connect my antenna directly to the RF-IN like this , i will do a little step of filtering)
Nico
    mcb1 over 8 years ago in reply to shabaz +3
    Usually you add an inductor to try and make the final stage think the antenna is matched, when in fact it isn't. Any mismatched antenna will not radiate 100%, so it's best to avoid them if you have low…
    shabaz over 8 years ago in reply to mcb1 +3
    We did the same too : ) and test with a short burst, it was very cool hearing the relays clicking away, doing their ATU selection : ) I didn't look closely at what the module was, but guessed it was a…
    shabaz over 8 years ago in reply to nicoloquinte +2
    Hi Nicolas, The part will be tiny (of the order of 1mm in dimensions) because of the capacitance mentioned earlier, that needs to be minimized, otherwise there will be no usable signal. 1mm is hand-solderable…
  • nicoloquinte
    nicoloquinte over 8 years ago in reply to shabaz
    Actually if the thing has 2 pins I already soldered successfully those tiny packages, my problem is more on ICs.
    And i don't think I'm overthinking It, my antenna has a connector on it and I already the cables.
    I'm only 17 so that's hard for me to buy these easy to make PCBs , $50 is way to much for a simple TVS and connectors but for other cool things like Peregrine Switches maybe  i will by eval boards.
    I'm only a beginner but I try to make really high quality stuff , I plan To make a second and better QFH antenna but the first one was actually quite good.
    I
    Thank you for all the answers, they made me learn a lot
    Nico
