Test & Tools
Test & Tools
Forum Help with PS3 power supply
  • Answers 2 answers
  • Subscribers 363 subscribers
  • Views 4209 views
Former Member over 9 years ago
Currently have a PS3 with a non-functional power supply (EADP-220BB) the output on molex connector is 5v just as it should be, however the 2 larger pins supposed to be putting out 12v, are not. I was looking for advice on how to further trouble shoot to find the broken component and possibly repair it.
I realize the replacements are available in the 20-30$ range, but this is more of a learning and experience effort. If I buy a new one and pop it in I learn nothing.
Any help or tips would be appreciated. thank you in advance.
-Dan
    Former Member over 9 years ago +2
    Thank you both for the quick reply. I will check everything out. I did leave the unit Unplugged for 24 hours after testing and before handling, just to be sure most if not all voltage was drained from…
    0 jw0752 over 9 years ago
    Hi Daniel,
    This is a switching power supply and it will have dangerous voltages inside. They also usually present a challenge to find and fix problems. When I went to the web to identify the Model EADP-220BB I found this video on you-tube that talks about how to repair this supply.
    https://www.youtube.com/watch?v=_ENdoxIVshM
    If you decide to go inside the power supply keep in mind the danger of shock or electrocution.
    Hi Daniel,
