Feedback and Support
F&S Forum Page changes painfully slow on Farnell website
200 X-Frame-Options: SAMEORIGIN Content-Security-Policy: frame-ancestors 'self'; X-UA-Compatible: IE=Edge X-XSS-Protection: 1; mode=block X-Content-Type-Options: nosniff X-Telligent-Evolution: 12.x Pragma: no-cache Connection: close Accept-Ranges: bytes Cache-Control: no-store, no-cache, max-age=0 Date: Mon, 22 Dec 2025 00:55:56 GMT ETag: "0x8DE317E31FF1C26" Set-Cookie: .te.csrf=cY9M4QckK1LZ5zzA8dh_uOO891J20QYLuF6O7fl0hfA; path=/; secure; SameSite=Lax Set-Cookie: .te.auth=_NlRtBXO1%2brdRdNJNvwaRj5nqC1OJXKbF9SSiPkaBJIMUqYCFIZdp%2bAx6tqpSusUZZYWhafJZqMxq0df6eauaNfbyyZ%2fDRuF3gyibfqoWdHysHTE%2fWVW0b5l%2f3ljK7tG7FvlB1CbGnyNW4VXrP2PGPjm2aYRUe0r0HVhKW82wAcNqOLpkoXWMwpg4baA73RgejoHvD6T4rFl1n9tLAzUkS8KUVJ1o82xMDMlVOumCSi2CmUyxAeaMK0D6Tk4vpnbFDvnJhKS2ccFogEXbWKPZqw%3d%3d; path=/; secure; HttpOnly; SameSite=Lax Set-Cookie: e14Guest=1; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Country=NL; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14Language=en; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Set-Cookie: e14TimeZone=Etc/UTC; expires=Fri, 31-Dec-9999 23:59:59 GMT; path=/; secure; HttpOnly Server-Timing: cdn-cache; desc=MISS Server-Timing: edge; dur=30 Server-Timing: origin; dur=44 Server-Timing: ak_p; desc="1766364956809_34604952_334098020_7321_5266_8_8_-";dur=1 Strict-Transport-Security: max-age=86400 ; includeSubDomains ; preload #set ($UserId = $core_v2_user.Accessing.Id) #set ($Roles = $core_v2_utility.MakeList('Moderators', 'Almost Admins', 'Administrators')) #set ($IsAdminLike = $e14_utils.IsUserInRoleOrAdmin($UserId, $Roles)) #if($IsAdminLike == 'False') #end
  • Locked Locked
  • Replies 72 replies
  • Subscribers 28 subscribers
  • Views 2727 views
  • Report Bug
rachaelp
rachaelp over 8 years ago
When trying to navigate between pages (the ones that work) on Farnell element14 UK - Electronic Components Distributor  it often take 10 seconds or more for the next page to load when clicking on a link. This makes navigating around to find products exceedingly tedious and will definitely be putting people off purchasing from Farnell. UX studies show that a lot of people will go elsewhere if pages take more than a couple of seconds to load. Here is a link I found on this topic https://velocitize.com/2017/03/27/how-site-speed-impacts-your-seo-and-ux/ and a quick search on Google will find a lot of results for pages showing similar statistics so at 10+ seconds I think there is significant cause for concern.
The problem isn't my internet connection, computer, or browser, it's definitely a problem with the Farnell website.
Best Regards,
Rachael
  • e14phil
    e14phil over 8 years ago +6
    Some one let the gremlins out
  • Dudley
    Dudley over 7 years ago +5
    I've been speaking with various teams to try to get to the bottom of this, and I have a plan for proceeding with this. I'm currently working on a theory that certain browser addons/extensions (ad blockers…
  • Sarribas
    Sarribas over 8 years ago +3
    Hi Rachael, Thanks sending us this feedback. We've opened a ticket for our Web Team to look into it. Kind regards, Sonia
  • ChristyZ
    ChristyZ over 7 years ago +3
    Hi everyone, Those of you who have recently posted that you're not seeing an improvement - johnr2 , valve5425f , Stillwaiting, PaulD, Jarl Einar Ottesad - our web technical team would really like to work…
  • rachaelp
    rachaelp over 8 years ago in reply to Sarribas +2
    Hi Sonia, Thanks for the update, hopefully your Web Team will be able to find the cause of the issue. FYI, today it seems worse than last night. I timed some pages at taking 29 seconds to load this morning…
    shabaz over 8 years ago in reply to rachaelp +2
    Speeds here are sadly behind the times : ( There will be a rollout of G.Fast in the UK to increase broadband speeds, but it is taking ages : ( Also, in some European countries, the 4G/LTE speed exceed…
  • valve5425f
    valve5425f over 8 years ago in reply to rachaelp +2
    Got to agree Rachael with your point about not using Farnell because, once you've managed to get the order in, their service is excellent. Can't fault customer service either. It's just so frustrating…
    michaelkellett over 7 years ago in reply to cstanton +2
    I'm really worried that you are looking at this as a Steve problem rather than a global Farnell problem. I had a little play today (9:00 am) and it seemed to be going about as well as it ever does the…
  • cstanton
    cstanton over 7 years ago in reply to mcb1 +2
    Google Chrome has a nice feature to let you see page loading in detail. So from the menu (three dots) go to tools -> more tools -> developer tools Then click on the 'network' tab, and now use the browser…
  • Dudley
    Dudley over 7 years ago in reply to Gough Lui +2
    Hi Gough Lui - while the stores aren't technically part of my remit, I've been talking for a while with some of our transactional team about this, and looked up the error references that you've passed…
    Former Member over 7 years ago
    Recently for me also, the Farnell website now throws up access denied using Firefox. I'm not interested in wasting time fiddling with browser setting etc. It should work. The folks looking after the website are paid to ensure that I would presume.
    Also, the filter parameters  are clearly not chosen  by engineers. They used to be good but now it's far better to use Mouser or Digikey. For example, I'm look for a panel mounted board to wire power connector. I go to wire-board connector and current rating is not a filter field – useless.
    I’m sorry to say after 18 years of using Farnell almost exclusively for my designs and putting Farnell stock codes into BOMs for my clients, I shall be looking elsewhere. Using the current Farnell website just take too long. Time is money.
    Why don’t the web team get a small group of real engineers to help them design something better for the user point of view, and pay them to do it.
