Embedded and Microcontrollers
Analogue Design 9V NiMH charging
  • Replies 14 replies
  • Subscribers 498 subscribers
  • Views 2746 views
  • charging
  • nimh
  • battery
9V NiMH charging
koudelad
koudelad over 1 year ago
9V batteries have always been a pain for me... Expensive, low capacity, almost every DMM / tester needed them.
I just bought a 9V NiMH battery: https://www.westinghousebattery.com/Ni-MH-Rechargeable/Premium-Series.html . To my surprise, it is not made from 6 smaller cells (which would give ca. 7.2-8.4 V), but 7, which has nominal voltage of 8.4, but when charged, can have almost 10 V. This makes it a true primary 9V battery replacement. I am not sure when these became available, but I remember older 6-cell "9 V" NiMH that were kind of useless, because all appliances thought the battery is discharged, due to the lower nominal voltage.
However, I never really had a charger for this kind of battery. I have heard that cheap chargers only use 12 V DC power supply with in series resistor in series to limit the current to ca 30 mA.
Do you have any suggestion for a charging circuit? I am open to building something, even using an MCU. I would love it to have a small small charging current (20-30 mA) or slightly higher (50 mA), a safety timer and the delta V detection. There is a famous old MAX713 charger, but according to the features, it offers C/4 to 4C charging and C/16 trickle charging, which is too high. Most commercially available hobby chargers also have a minimum current of 100 mA.
Thank you,
David
    shabaz over 1 year ago in reply to shabaz +5
    I had some time, to lay out the PCB. This board is 100 x 60 mm and several different PP3 battery holders will fit. All parts are jellybean. The optional microcontroller is connected to the row of pin-headers…
    shabaz over 1 year ago +3
    I think the circuit below would do it. It's based off of a simpler charger here: Smart Doorbell System – Part 6 – Chime Module Complete Circuit Design and based on information from a battery mnfr PDF doc…
    genebren over 1 year ago in reply to shabaz +3
    Very Nice! This is something that I would like to look into further in the future. I really do appreciate your efforts to assist and to promote a true sense of community here on element14!
  • scottiebabe
    0 scottiebabe over 1 year ago
    I use a USB-C PD module, diode, resistor, and ohms law FTW.
    If you want to make your own PCB you could consider an switching LED driver and design around a 5V USB input.
    One random example:
    ww1.microchip.com/.../mic2287c.pdf
  • scottiebabe
    One random example:
    0 dougw over 1 year ago in reply to scottiebabe
    Cool idea, but I'm wondering if it would tend to try to overcharge, as it tries to maintain a constant current?
