Raspberry Pi Forum can i build an led cube and to control it with raspberry
  • Replies 18 replies
  • Answers 13 answers
  • Subscribers 679 subscribers
  • Views 2371 views
images?q=tbn:ANd9GcRqC9Gqane0sozu4TkkAGalkeFBBh-Np5H5fJ2tAw1eUVDPK-GNJLwm7AHello im wondering if is there any possibility to use raspberry as a controller for the led cube ?
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    for smooth operation though i'm not sure if the PI will be up to the task, having it as a master and sending the pattern requests to the Arduino is good. I have not yet seen a PI do this. Not saying it cant be done but to be honest, a PI is not the best choice for hardware control of this nature. An Arduino or similar (MSP430, TivaC etc) is much more adept.
    0 Robert Peter Oakes over 11 years ago in reply to Robert Peter Oakes
    Like this http://jacksonliam.blogspot.ca/2012/06/arduino-and-raspberry-pi-talking-over.html
    Peter
    better link here with reasons http://www.raspberrypi.org/forums/viewtopic.php?f=38&t=10120
  • kidiccurus
    0 kidiccurus over 11 years ago in reply to Robert Peter Oakes
    Or just skip the pi and go straight to 'duino.
    0 michaelkellett over 11 years ago in reply to kidiccurus
    To make  a decent LED cube you need to get away from weedy little processors or RP with it's lack of IO and poor real time perfromance.
    This guy shows you how do it right http://www.hownottoengineer.com/projects/rgb-led-cube.html
    (And lot's of good explanation.)
    If I were doing it I would use an FPGA (which would get rid of the LED driver chips) but that's because I use them all the time so I have all the tools.
  • kidiccurus
    0 kidiccurus over 11 years ago in reply to michaelkellett
    You don't necessarily need a driver chip with an arduino. For a 4x4x6 cube I am working on the only io expansion I am using is a single Johnson counter. This is using an arduino Leonardo.
  • kidiccurus
    How will you get any power into your LEDs without drivers - you have 96 LEDs (which is a lot less than the 512 for an 8 x 8 x 8) cube but the maximum total current you can put out is less than 200mA  which won't be very bright. (Perhaps I'm missing something - can you post a sketch of your ciruit ?)
    0 Robert Peter Oakes over 11 years ago in reply to michaelkellett
    that's total for the chip too, you are limited also to 20mA per pin, absolute max being 40mA but not recommended and that would also be dropping a lot of volts in the chip
