Arduino Forum MQTT client program not showing any results with Arduino
  • Replies 49 replies
  • Subscribers 414 subscribers
  • Views 5965 views
I modified the MQTT example present under MQTT library pubsubclient for Arduino.
My MQTT server address is 192.168.1.6 with port 8081.
To this MQTT server,another MQTT client in my mobile is able to connect.
But this is not working with Arduino.There is no error shown during compilation or during uploading.
Infact,I am not able to see the connection result messages such as "Connected" or "Not connected" which i given in Serial.println() in setup function.
I am resetting Arduino before uploading the program.Please let me know why this is not showing any output....
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// Update these with values suitable for your network.
byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
byte server[] = {192, 168, 1, 6 };
//byte ip[]     = { 172, 16, 0, 100 };
void callback(char* topic, byte* payload, unsigned int length) {
  // handle message arrived
EthernetClient ethClient;
PubSubClient client(server, 8081, callback, ethClient);
void setup()
  Ethernet.begin(mac);
  if (client.connect("*")) {
     Serial.begin(9600);
    Serial.println("Connected to MQTT Server");
    client.publish("outTopic","hello world");
   // client.subscribe("inTopic");
  else
   Serial.println("Could not connect to MQTT Server");
void loop()
  //client.loop();
  • neilk
    neilk over 11 years ago in reply to Former Member +3
    generk4 and organtin Hi Radhamani and Giovanni - I had 30 minutes to spare so I copied the program from comment 19 and posted it into the Arduino IDE (I am using 1.6.1), compiled and uploaded it to a genuine…
    Former Member over 11 years ago +3
    Hi Bob, Neil and Clem, I tried LM35 Temperature sensor with MQTT Arduino sketch and it works fine for me I am sooo happy Thanks once again for your wonderful support and help
    Former Member over 11 years ago in reply to bobcroft +2
    Hi bob,Neil,Clem and many others who have helped and guided me in this issue, I have successfully completed MQTT program and Arduino is successfully publishing and subscribing messages Next step,I am going…
    Hi Peter Oakes,
      Thanks..That and many others can also be added as reasons..
       I have given these lessons learnt from my side since I didnt have issues with DHCP server...
    I didnt press the Ethernet shield properly..Also,I had a faulty Ethernet shield..
    Hi Peter Oakes,
