WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Pros and Cons of Low-Temp Solder Paste - Workbench Wednesdays 46
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 25 Oct 2021 7:29 PM Date Created
  • Last Updated Last Updated: 3 Nov 2021 8:24 AM
  • Views 3497 views
Low-temperature solder paste makes it easier to reflow solder and re-work surface mount circuit boards. MG Chemicals offers a Bismuth-based paste that works great from larger passive components to fine pitched packages, like QFN. In this video, learn what solder paste is, what it means for a paste to be “low temperature,” and some things to watch out for when using it.
Supplemental Content:
  • Solder Paste Basics, Martin Tarr (Web Archives)
  • 57Bi-42Sn-1Ag: A Lead-Free, Low Temperature, Hewlett-Packard
Bill of Material:
Product Name Manufacturer Quantity Buy Now
Low Temperature Solder Paste 15g syringe MG Chemicals 1 Buy Now
Low Temperature Solder Paste 25g syringe MG Chemicals 1 Buy Now
No Clean Flux Syringe MG Chemicals 1 Buy Now
Workbench Wednesday
element14 presents  |  About James |  Workbench Wednesdays
  • mg chemicals
  • bismuth solder
  • lead-free solder alternative
  • e14presents_baldengineer
  • solder paste
  • workbench wednesdays
  • reflow soldering
  • koudelad
    koudelad over 4 years ago
    Nice video! You mentioned mixing this low temperature alloy with an existing solder - that is how Chip Quick works for removing chips and other parts from assembled PCBs (no advertisement intended): https://www.chipquik.com/store/index.php?cPath=200
    They claim the melting point is VERY low, below 100 Centigrade. https://www.chipquik.com/datasheets/SMD1NL.pdf
    It is very important to remove the mixed alloy after removing the part, because it would heavily affect the the melting point when soldering a new part in (and I believe it could easily corrode.)
  • scottiebabe
    scottiebabe over 4 years ago
    Would have been handy when I tried to rework a hot bar soldered display flex. Neat product.
    DAB over 4 years ago
    Good episode.
    I did not know much about the solder paste options, so I found this overview very interesting.
