Project Videos
  • Project Videos
Project Videos
Documents Member Challenge Accepted - Universal LANC Controller for DSLR cameras -- Episode 595
  • Date Created: 16 Mar 2023 4:52 PM Date Created
  • Last Updated Last Updated: 24 Mar 2023 8:24 AM
  • Views 24187 views
  • Likes 11 likes
  • Comments 14 comments
The element14 community asks and Clem delivers. This time we are building a project suggested by one of our community members. An affordable open source alternative to expensive filmmaker gear, that allows anyone to control the focus and zoom of manual DSLR lenses similar to expensive professional Lanc and focus pulling systems. Clem wants to one up the commercial solutions in one key aspect, the unit has to be fully self contained, so no external battery packs needed. that is quite the challenge as it means he tries to run a Nema 17 stepper motor from just a single Lipo cell. Clem really needs to step up his power supply game for this project ;)
Watch the Video:
Bonus Content:
  • Download all the CAD and Code for Free
Bill of Material:
TRINAMIC / ANALOG DEVICES Evaluation Board, TMC2100 Bipolar Stepper Motor Driver, For StepStick TRINAMIC / ANALOG DEVICES 1 Buy Now
ONSEMI Linear Voltage Regulator, 7805, Fixed, 35V In, 5V And 1A Out, TO-252-3 ONSEMI 2 Buy Now
SANYO DENKI Stepper Motor, Single Shaft, 42 mm, Bipolar, 1.8 °, 0.186 N-m, 1 A SANYO DENKI 1 Buy Now
ANALOG DEVICES DC-DC Switching Buck, Boost Regulator, Adjustable, 2.3 to 5.5V in, 2.8 to 5.5V/1A out, LFCSP-10 ANALOG DEVICES 1 Buy Now
VISHAY Power Inductor (SMD), 1.5 µH, 9 A, Shielded, 18 A, IHLP-2525CZ-01, 2525 [6363 Metric] VISHAY 1 Buy Now
MULTICOMP PRO SMD Multilayer Ceramic Capacitor, 0.1 µF, 50 V, 0603 [1608 Metric], ± 10%, X7R, MC MULTICOMP PRO 4 Buy Now
MIKROELEKTRONIKA Rechargeable Battery, 3.7 V, Lithium Polymer, 2 Ah, JST MIKROELEKTRONIKA 1 Buy Now
MULTICOMP PRO Audio / Video Cable Assembly, 3.5mm Stereo Jack Plug, 3.5mm Stereo Jack Plug, 3.9 ft, 1.2 m, Black MULTICOMP PRO 1 Buy Now
MOLEX USB Connector, USB Type C, USB 3.1, Receptacle, 24 Ways, Surface Mount, Right Angle MOLEX 1 Buy Now
MCP73832T-2ACI/OT MICROCHIP 1 Buy Now
AP9101CK-AHTRG1 DioDES inc 1 Buy Now
DMN2024UQ-7 DioDES inc 2 Buy Now
DM1231-02SO-7 DioDES inc 2 Buy Now
Rotary encoder Bourns 1 Buy Now
3,5mm jack Kycon 2 Buy Now
Additional Parts:
MAYER MAKES Engineering Resin for the Case
Closed loop GT2 belt, Idlers and Pulley salvaged from a 3d printer.
DSLR Camera with manual Lens (Example shown Nikon d3300 and vintage Canon Fd lens)
element14 presents
element14 presents  |  About Clem  |  Project Videos
  • dc-dc
  • dslr
  • molex
  • focus pulling
  • diy
  • stepper motor
  • linear voltage regulator
  • analog devices
  • Filmmaker gear
  • boost regulator
  • friday_release
  • e14p_CMM
  • mayermakes
    mayermakes over 3 years ago in reply to rbj
    1) alert the internets tariq.ahmad
    2) the two idlers are premade parts. I did not have smooth ones. smooth ones would do fine, the decision was for availability and knowing the belt would glide smoothly on aluminium while a 3d print might have more friction + I did not have suitable bearings in stock for a printed version.
  • rbj
    rbj over 3 years ago
    Two notes:
    1) The link above for "All the CAD and code" fails with a page not found message. Presumably it worked at one time, but it's broken now.(community.element14.com/.../147337)
    2) The two tension pulleys were printed with gear teeth on them, but they only touch the smooth side of the belt, making the teeth redundant - see the video at time 20:06. Was this an oopsie, a conscious choice, or did you simply reuse an existing part? (And of course, if it was a choice ... please say why).
  • mayermakes
    mayermakes over 3 years ago in reply to cstanton
    you will b e held accountable by your 3d printers anonymous buddy.
  • mayermakes
    mayermakes over 3 years ago in reply to phoenixcomm
    i have a commercial sidefocus for dslrs and the side loads are very comparable, moreover because the adjustments for the positioning of the motor(and in return the tension) is just held by friction, excerting to much force is not of aconcern as the camera would just turn a bit when the load gets to big, same with reachign endpositions (the belt just slips).
    A 3d printed ring with GT2 teeth would improve trackiong, but also loose this little safety feature. OS there are tradeoff to be made.
    for bigger lenses I would certainly recommend to print a ring with the right teeth as it might slip during fast movements.
  • mayermakes
    mayermakes over 3 years ago in reply to DAB
    sure it can, if you don't need reproducable positions than any motor can work even without encoder.
    I chose the stepper specifically for torque and reproducability of positions.
  • mayermakes
    mayermakes over 3 years ago in reply to adamsoileau1
    I copied the belt design from a Community memebers reply on the original post, i just altered it to mount to the camera base instead of directly to the lens.
  • mayermakes
    mayermakes over 3 years ago in reply to dougw
    oh yes that is a good idea!
  • mayermakes
    mayermakes over 3 years ago in reply to baldengineer
    one of the things I really hope for is some community memebers with software skills taking up stuff like this and improving it, because my bytewrangling os not even halfbaked enough.
  • phoenixcomm
    phoenixcomm over 3 years ago
    Clem, Good Solution. But the camera lens does not take kindly to large or even small side loads! Just a thought what would happen if you attached a 3D-printed gear to the lens ring?  just think of how you hold the camera and use just two fingers on the focus ring. You could do the same thing.  ~~ Cris
    DAB over 3 years ago
    Great build Clem.
    I wonder if a pulsed DC motor could be used instead of the stepper motor.
