1 Meter of Pi
  • 1 Meter of Pi
1 Meter of Pi
Blog Blog# 6 EAS - System Designs -- Block diagram
  • Author Author: skruglewicz
  • Date Created: 3 Nov 2020 5:01 AM Date Created
  • Views 2454 views
  • Comments 8 comments
  • eas
  • 1meterofpi
  • 1meter of pi
skruglewicz
skruglewicz
3 Nov 2020
BLOG# 6 -Edible Algae System - (Growing Spirulina in space)
This is my 6th blog post in a series of blog post for the Design Challenge 1 Meter of Pi
Updated version 1.3
<<<   PREVIOUS BLOG
NEXT  BLOG  >>>
Blog# 5 EAS - Research Temperature Sensor - DS18B20Blog# 7 EAS -  System Designs -- Software Design
    • System Designs -- Block diagram
  • INTRODUCTION
  • SYSTEM BLOCK DIAGRAM
  • Conclusion and summary
INTRODUCTION
  • In this blog, I wanted to map out the relationships in the System between the:
    • Raspberry PI
    • PICO HAT
    • Automation Hat Mini
      • Outputs from the hat
    • Enviro colimit Hat
      • Sensors, on the Hat
  • Water Temperature sensor probes.
  • WIFI
  • DB server,
    • Saving data to Mongo DB Atlas in the Cloud
    • Monitoring data over a timespan using Atlas Charts
  • I wanted to have one Pi connected to both hats and the Wiring image below, shows that. It's not pretty, but it works
  • Basically is a splitter breadboard for all the GPIO pins shared by both hats and there is a direct connection from the pins to the hats where they don't share.
  • The next Breadboard splitter, is used for the Water Temperature sensor. circuit and is connected to The main Splitter
  • The last Breadboard Splitter circuit, is used to implement the Three output switch's , to control the room light water pump and water heater.
  • This blog has summarized a high level design on how the PI, Hats, and other electrical components will be interconnected.
  • The implementation of this first pass has changed a bit:
    • the Hats are wired to one PI and the DB Server and Windows server, replaced with MongoDB Atlas in the cloud.
      • The Data is sent to Atlas using the Python Driver (pymongo),.over a wireless connection
      • The Data is monitored using Atlas Charts.
    • The PH sensor will not be implemented in this phase.
  • I plan on implementing  this design in a phase II implementation. I want this to be a self contained system without wireless connectivity. With a MongoDB server runing On another PI.
<<<   PREVIOUS BLOG
NEXT  BLOG  >>>
Blog# 7 System Designs -- Software Design
    DAB over 6 years ago +2
    What are you using for the Ph sensor? DAB
    DAB over 6 years ago in reply to skruglewicz +1
    That is why I asked. There are some very expensive solutions so I was curious if you have found an economical way to measure PH. DAB
  • feiticeir0
    feiticeir0 over 6 years ago in reply to DAB +1
    There are cheap PH sensors (around 18€) compatible with Arduino and Raspberry PI . I have one to be incorporated in my project. What I don't still know is if I can leave it in the solution all the time…
  • skruglewicz
    skruglewicz over 6 years ago in reply to DAB
    Hi DAB
    i haven’t decided yet.
    it’s looking like the products I’ve seen on the Internet are pretty expensive for my budget I might just not do this option now. I’ll be sure to change my diagram.
  • skruglewicz
    OK I'll put that feature on my design back burner for now.
  • feiticeir0
    There are cheap PH sensors (around 18€) compatible with Arduino and Raspberry PI . I have one to be incorporated in my project. What I don't still know is if I can leave it in the solution all the time or not. Need to read a bit more about it.
    Here it is:
    https://www.aliexpress.com/item/1005001612930856.html?spm=a2g0o.productlist.0.0.6af86110B0Xwfm&algo_pvid=b80ac9e7-403f-42aa-acbf-3fcb9a385299&algo_expid=b80ac9e7-403f-42aa-acbf-3fcb9a385299-3&btsid=2100bb4916063199833871898edf6b&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
    DAB over 6 years ago in reply to feiticeir0
    I would be interested to see how long it lasts.
    These sensors are notorious for failing.
