At The Core Design Challenge
  • At The Core Design Challenge
Blog Winners - At The Core Design Challenge
Join At The Core Design Challenge to participate - click to join for free!
  • Author Author: e14phil
  • Date Created: 24 May 2023 1:23 PM Date Created
  • Views 5467 views
  • Likes 20 likes
  • Comments 31 comments
  • infineon
  • compeititon
  • winners
  • at the core
e14phil
e14phil
24 May 2023
Challengers are tasked with pushing the limits newly unleashed M0 Dual Core on the PSoCTm 62S4 with Infineon’s ModusToolboxTm   Platform.
design challenge profile
About this Challenge | Dates | The Judges | The Kit | The Prizes | Example Application | Terms & Conditions | The Challengers
Winners
After months of creating, coding and making, please help congratulate the Winners and Finishers of the At The Core Design Challenge
Challengers will be sent prizes to the addresses listed on their applications.
What was the Challenge
Get to the Core of the PSoCTm 6 microcontroller with multi-core project workflows found in ModusToolboxTm 3.0
Challengers were tasked with pushing the limits of the newly unleashed Arm® Cortex®-M0+ core on the PSoCTm 62 dual-core microcontroller with Infineon’s ModusToolboxTm software development platform.
With the release of ModusToolboxTm 3.0, Infineon invites you to create projecuts that take advantage of the dual core architecture of the PSoCTm 62 microcontroller. Whether your application is looking to leverage dual core for low power modes, to securely partition the cores, or to drive multiple operating systems on a single microcontroller, the PSoCTm 62 with ModusToolboxTm 3.0 helps to ease your development efforts.
The sponsored challengers must use the ModusToolboxTm 3.0 development environment as well as demonstrate use of both the Cortex-M0+ and Cortex-M4 cores in their project.
The Kit
The Sponsored Kit The Specs
PSoCTm  62S4 Pioneer Kit x 30qty
Buy Now
PSoCTm 62S4 pioneer kit (CY8CKIT-062S4) is a low-cost hardware platform that enables to design and debug applications using the PSoCTm 62 MCU.
The PSoCTm 62S4 Pioneer Kit features the PSoCTm 62 MCU CY8C62x4 (CY8C6244LQI-S4D92) with:
  • 150-MHz Arm® Cortex®-M4 and 100-MHz Arm Cortex-M0+ cores,
  • 256KB of Flash
  • 128KB of SRAM
  • programmable analogue blocks including two 12-bit SAR ADCs
  • programmable digital blocks, Full-Speed USB, a serial memory interface
  • a CAN-FD interface and industry-leading capacitive-sensing with CapSenseTm.
  • 512Mbits quad SPI nonvolatile flash provides high-performance, safe NOR flash memory solution
  • Rich analogue including dual SAR ADCs, DAC, Opamps and comparators
  • Capable of operating in system deep sleep mode
  • Industry leading CapSense (4th generation CapSense)
  • Capacitive sensing interfaces including two buttons and a 5-segment slider
  • ModusToolboxTm software suite
The Prizes
Prize Prize Category
Grand Prize Winner
Approximate Value $1770 USD*
Microsoft Surface 256GB 16GB RAM Platinum + Sonos One (Gen 2) Two Room Set Voice Controlled Smart Speaker with Amazon Alexa Built in (2-Pack White
Runner Up
Approximate Value $746 USD*
Microsoft Surface Go 3 - 10.5 Inch 2-in-1 Tablet PC - Silver - Intel Pentium Gold G5600, 8GB RAM, 128GB SSD + Sonos One (Gen 2) - The Powerful Smart Speaker with Alexa Built-In, Black
Finisher Prize**
To be a finisher you must complete 5 blogs and show us testing the resilience of their project.
Approximate Value $62 USD*
Fitbit Inspire 2 Health & Fitness Tracker with a Free 1-Year Fitbit Premium
*Or local equivalent
**Grand Prize and Runner Up winners also earn the finisher prize.
The Judges
element14 Community Judges
element14 Community Team
Infineon Technical Judges
Clark and Lawrence
Grand Prize Winner
 Digimorf  – IT – ATCDC The project SEGA SG-1000 Emulator on PSoC62S4 Pioneer kit
/members/digimorf/blogs
Judges Notes:
This project managed to make use of all of the available compute power available in a microcontroller. Great work bringing this to completion and demonstrating the power of multi-cores. The use of DMA to generate VGA output is a great idea. Great use of the various configurators and tuners built into ModusToolbox.
This was absolutely and incredible project to watch develop.  With pitfalls and challenges along the way, a real nail biter at the end.  Great use of ModusToolbox, from using the Device Configurator to DMA and Linker File edits.  DigiMorf really pushed the limits of the development kit and the onboard components.
 Runner Up Winner
 taifur  – BG – Alphabet Learning Toy
/members/taifur/blogs
Judges Notes:
This is a great project, both for your own learning of microcontroller programming, and for you daughter’s learning of the alphabet.
What a great reason to develop an embedded application.  This project showed excellent use of the middleware available within ModusToolbox from emWin graphics to CAPSENSE.
Finisher navadeepganeshu   – IN – Exploring IPC with PWN, ADC for Motor Control
/challenges-projects/design-challenges/at-the-core-design-challenge/b/blog/posts/atthecore-blog-5---brining-altogether-tmulti-core-deployment-and-application
Judges Notes:
This blog series good example of interfacing multiple peripherals  (light sensor, cap sense, PWM, LED bars, and motors) to a microcontroller, then dividing the work across the cores. Greak work.
The series of blog associated with this entry are very well done, and will serve as an excellent resource for many other community members.
Finisher - guillengap  – MX – Infineon Beverage Dispenser
/challenges-projects/design-challenges/at-the-core-design-challenge/b/blog/posts/infineon-beverage-dispenser-7---summary
Judges Notes:
Great idea,  I like that you started with a built-in project to get started with the capsense demo app, then incrementally adding adding a motor driver and controlling it with the pwm, then adding the OLED display and working around the memory usage constraints. Mechanical assembly of a full system makes the project more complete. Hope you will have a chance to complete the display, and have the proximity and liquid level sensors connected to the second core to automate the fill process.
This project was a very cool concept, and it was amazing to see both the embedded project and the physical dispenser materialize.  Great use of the ModusToolbox Library Manager to leverage a code example created for one development kit on to another one.
Finisher fyaocn   – CN – Tennis Ball Picker Machine
/challenges-projects/design-challenges/at-the-core-design-challenge/b/blog/posts/tennis-picker-the-core-1-the-first-move
Judges Notes:
This project was a very ambitious task for a microcontroller. You made great progress and described your work to date very well. I hope you will complete the project and update the blogs.
 This was a super ambition project and a great concept for the design challenge.
Finisher skruglewicz – USA – “Get to the Cores - Push the limits of ModusToolbox 3.0 multi-core Embedded Firmware Development”
/members/skruglewicz/blogs
Judges Notes:
This project is a great tutorial introduction to all of the components that will be merged together for the overall project.  Excellent details on the steps and pitfalls when moving between versions of ModusToolbox and how to test all of the components used I the project. Overall a great learning experience.
 This project really captures the quintessential dual-core use case.  Great use of and RTOS and baremetal
Finisher aaryan2134  – IN – Uncover The Cores (Dual CoreTech Demo)
/members/aaryan2134/blogs
Judges Notes:
Thank you for detailing the steps of your learning and use of the PSoC Kit and the dual cores to independently process data from multiple sensors.
This project showed an excellent way to expand on the available semaphore code example with onboard sensors.
Finisher - sandeepdwivedi17  – IN – Adaptive Brightness Feature to Protect Your Eyes from Strain and Fatigue
/members/sandeepdwivedi17/blogs
Judges Notes:
This project made good use of an co-application running on a PC to process the sensor readings taken by the microcontroller and adjusting the screen brightness. Further work could be done to use the capsense buttons to manually adjust brightness.
Finisher rahulkhanna  – India  – Neonatal Monitor
/challenges-projects/design-challenges/at-the-core-design-challenge/b/blog/posts/neonatal-incubator-monitoring-system---summary-5
Judges Notes:
Great idea with lots of impact in the world. The Blynk dashboard is a good way to monitor the collected data.
Please congratulate our winners and check out their blogs!
I want to extend a Thank you to the wonderful team at Infineon and our amazing judges Clark and Lawrence.
  • scottiebabe
    scottiebabe over 3 years ago +3
    Congrats and Great work!
  • aaryan2134
    aaryan2134 over 3 years ago +3
    Congratulations everyone!! Especially Digimorf & taifur
  • srutledge
    srutledge over 3 years ago +3
    Quick update regarding prizes: Grand and Runner-up prizes should be on their way shortly. Finisher prizes will be a little longer of a wait due to the quantity we ordered, however we will send them out…
  • taifur
    taifur over 3 years ago in reply to aaryan2134
    Thanks
  • aaryan2134
    Especially Digimorf  & taifur TadaTada
    dougw over 3 years ago
    Congratulations on your projects. Some very impressive work.
  • scottiebabe
    shabaz over 3 years ago
    Congrats everyone!
