Blog Bluetooth Unleashed : AAPSAD #5 : Audio and Visuals
  • Author Author: sakthi.1260
  • Date Created: 2 Jun 2018 4:34 PM Date Created
  • Views 2075 views
  • Likes 8 likes
  • Comments 6 comments
  • rpi 3b+
sakthi.1260
sakthi.1260
2 Jun 2018
Hello guys,
Before I start, apologies for not responding to your comments, although I've been going through them I couldn't reply  to you guys have been running on a tight schedule.
Previously in Bluetooth Unleashed....
With no clue on recognizing facial expressions our hero was struggling to find a good API and finally ended in way to detect smiles and proceeded further.....
Now on Bluetooth Unleashed
Still unhappy with results and working with APIs in Parallel, I found out Google Vision to be satisfactory.
They have a very good documentation and found this YouTube Video to be much easier.
What I've done here is:
1) I've used OpenCV and a python script to capture an image and save it locally as emo.jpg, and call another python script (the Vision API).
2) This one Upload to the GCloud and returns a json response from which emotions could be fetched.
capture.py
import cv2
import numpy as np
import sys
import time
import os
facePath = "haarcascade_frontalface_default.xml"
faceCascade = cv2.CascadeClassifier(facePath)
cap = cv2.VideoCapture(0)
cap.set(3,640)
cap.set(4,480)
sF = 1.05
while True:
  ret, frame = cap.read()
  img = frame
  gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
  faces = faceCascade.detectMultiScale(
    gray,
    scaleFactor= sF,
    minNeighbors=8,
    minSize=(55, 55),
    flags=cv2.CASCADE_SCALE_IMAGE
  if (len(faces)):
     cv2.imwrite(filename = 'emo.jpg', img=frame)
    print('opening API')
    os.system('python emotion.py')
    time.sleep(10)
  c = cv2.waitKey(7) % 0x100
  if c == 27:
        break
cap.release()
This calls for the emotion.py which in turn return emotion values.
The next part is to play a soothing visual with a audio according. Will be using omxplayer to run them, I'm yet to find the proper visuals and audios. For now 3 music videos each emotions.
modified the emotion.py to play videos.
emotion.py
import io
import os
# Imports the Google Cloud client library
from google.cloud import vision
from google.cloud.vision import types
# Instantiates a client
client = vision.ImageAnnotatorClient()
# The name of the image file to annotate
file_name = 'emo.jpg'
# Loads the image into memory
with io.open(file_name, 'rb') as image_file:
    content = image_file.read()
image = types.Image(content=content)
# Performs label detection on the image file
response = client.face_detection(image=image)
faces = response.face_annotations
# 0-'UNKNOWN',1-'VERY_UNLIKELY',2-'UNLIKELY',3-'POSSIBLE',4-'LIKELY',5- 'VERY_LIKELY')
for face in faces:
    anger = face.anger_likelihood
    joy = face.joy_likelihood
    sorrow = face.sorrow_likelihood
#print(anger) print(joy) print(sorrow)
if (anger >= joy) and (anger >= sorrow):
   emo = 'a'
elif (joy >= anger) and (joy >= sorrow):
   emo = 'j'
else :
   emo = 's'
if emo == 'a' :
  os.system('omxplayer Anger.mp4')
  os.system('killall omxplayer.bin')
if emo == 'j' :
  os.system('omxplayer Joy.mp4')
if emo == 's' :
  os.system('omxplayer Sorrow.mp4')
I just ran the capture.py from putty and within 2seconds this came up on the Rpi screen
Here's a short clip on the output...
  • BigG
    BigG over 8 years ago +3
    Nice update. Have you looked into TensorFlow and their version for embedded systems: https://www.tensorflow.org/mobile/tflite/
    DAB over 8 years ago +3
    Good progress, I look forward to seeing the emotion algorithm in operation. DAB
    genebren over 8 years ago +2
    Nice update to your design challenge project. Looking at your last image and the last results, it looks like you totally nailed the 'joy' emotion, both in your ability to show joy and the programs ability…
  • BigG
    Nice update.
  • BigG
    Nice update.
  • sakthi.1260
    sakthi.1260 over 8 years ago in reply to BigG
    Hi,
    That was my first choice of preference had some issues with dependencies and had to use a bigger data set for making it properly work, so had to find something much easier to process, APIs were my first thought but there was a lot of them, had tried a few and finally settled with Google Vision.
    Cheers,
    Sakthi
