Blog Stirling Blue - Fuel Measurement - Blog 4
  • Author Author: dougw
  • Date Created: 21 May 2018 4:27 AM Date Created
  • Views 2486 views
  • Likes 17 likes
  • Comments 6 comments
  • stirling blue
  • doug wong
  • fuel measurement
  • bluetooth unleashed
  • bluetooth unleashed design challenge
dougw
dougw
21 May 2018
The Stirling Blue project will be measuring several Stirling engine parameters including inputs and outputs so I can calculate efficiency. The input to the engine is fuel - alcohol in this case, and I will need to know how much is consumed. I could do a before and after weight measurement, but I want the PSoC6 to be able to monitor all parameters in real time. The gas tank is actually a 10 ml glass jar. The fuel is drawn out using a wick that also acts as the burner. This blog explores using capacitance to measure fuel level in the jar. I did an earlier road test of the TI FDC2214, which is a very accurate capacitance measurement circuit. This will be a good choice for measuring such a small jar. It uses an I2C interface so I will have to figure out how to get the PSoC6 talking to it.
Capacitance sensing of the fuel level with the FDC2214 works well. I may double the width of copper tape on the bottle to increase the capacitance values.
Upcoming blogs:
Blog 5 will be about how Stirling engines work
Blog 6 will start connecting some sensors to the PSoC6
Blog 7 will be about designing the sensor interface PCB
Related Links:
Bluetooth Unleashed Design Challenge: The Challengers
Bluetooth Unleashed Design Challenge: About This Challenge
Links to other blogs for this project:
Stirling Blue - Project Description - Blog 1
Stirling Blue - Unboxing Hero - Blog 2
StirlingBlue1
Stirling Blue - micro:bit TXTR - Blog 3
    mcb1 over 8 years ago +4
    Good work. Be interesting to see the rate of change with different vessels. The fact it's linear is a good start. Mark
    dougw over 8 years ago in reply to genebren +4
    It should burn at a pretty steady state rate so I can take some time to get a more precise measurement of level change.
    genebren over 8 years ago +3
    Doug, Great update on your project. The results do look promising. I am not sure how much fuel would normally be consumed during the running of your engine, but the rate of change on a few picofarads might…
    shabaz over 8 years ago
    Hi Doug,
    Very interesting fuel measurement! Looking forward to learning about Stirling engines in your upcoming blog.
    jw0752 over 8 years ago
    This is an example of being able to reach back and draw on previous experiments to solve present day problems. It is always fun to watch a master at work.
  • aspork42
    aspork42 over 8 years ago
    Dang - you have developed what looks like a quite reliable and usable method of measurement. Probably just a simple running average and you can get at least 2 decimal places of accuracy.
    Nice job!
    Doug,
    Great update on your project.  The results do look promising.  I am not sure how much fuel would normally be consumed during the running of your engine, but the rate of change on a few picofarads might be difficult to determine (or maybe not).
    Good luck!
    Gene
