Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Booting the Yún
  • Author Author: Workshopshed
  • Date Created: 25 Jun 2015 4:13 PM Date Created
  • Views 1567 views
  • Comments 5 comments
  • enchanted_cottage
  • enchanted_objects
Booting the Yún
Workshopshed
Workshopshed
25 Jun 2015
As mentioned it the demo video and Enchanted Objects Design Challenge - And they all lived happily ever after the Arduino Yún takes a long time to boot. I did notice that there's a bit of a difference between different file systems on the SDA. I also collected together some links in my research which give ideas on speeding up this process.
One tool that might help is BootChart that gathers some stats and presents them as a chart, as with a lot of things on the Arduino Yún this is for standard Linux so might not work for the Yún platform.
Boot Chart
Booting
http://wiki.openwrt.org/doc/techref/process.boot
https://lwn.net/Articles/299483/
http://www.bootchart.org/
http://forum.arduino.cc/index.php?topic=236696.0
http://free-electrons.com/doc/training/boot-time/
http://forum.arduino.cc/index.php?topic=324304.0
http://forum.arduino.cc/index.php?topic=324086.0
http://codesnippets.altervista.org/documentation/yun/boot_running/boot_running.html
http://codesnippets.altervista.org/documentation/yun/boot_process/rcS_process.html
http://forum.arduino.cc/index.php?topic=290149.0
https://gist.github.com/wayoda/db3c023417757f726088
    Jan Cumps over 11 years ago +2
    The slow booting is annoying when you're making a video. But in the big scheme of things, where your device will be on for months, it may not be that significant. The analysis tool is cool. I get around…
  • Workshopshed
    Workshopshed over 11 years ago in reply to balearicdynamics +1
    I found it on Google, I believe it is generic Linux
    Andy, very interesting this method. Please can you give more information about this booth-checker ? Is for Yun only?
    Thank you. Enrico
  • Workshopshed
  • Workshopshed
    balearicdynamics over 11 years ago in reply to Workshopshed
    Found it too. The charting method is very interesting, I should check if it works on the Raspberry. Then I have also downloaded the sources; the idea I was searching for something is to use the logging / capture mechanism of this tool at this very low level (I see that it is set as a Grub/Lilo standard booting alternative) to track the booting process. Not only to make a graph but to give to the master PI the ability to know what's happening to the other networked units.
