Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Enchanted Objects Design Challenge - Photo Story
  • Author Author: Workshopshed
  • Date Created: 25 Jun 2015 5:06 PM Date Created
  • Views 1816 views
  • Comments 8 comments
  • enchanted_cottage
  • enchanted_objects
Workshopshed
Workshopshed
25 Jun 2015
Some photos that were taken during the project.
{gallery:width=600,height=600} Photo Story
Enchanted Cottage: Before it was taken apart.
Mechanical Prototype: Cardboard and brass tacks
Multiprint: Printing lots of parts for the mechanism
Test Jig: For testing servos
Cutting: Strips of wood for the substructure
Planks: Initial pass at the frame parts
Printing: Printign the mechanism
Battery Delivery: Matilda checks out the new battery
Captive Nuts: Nuts to support rods to support PCBs
Battery Test: Testing the battery
Infineon Low Power: Testing low current options with the Infineon RGB Shield
LED: A mini PCB
Golem: Hans and Matilda's Metalworking Friend
Pins: Pins and Headers
Rimage
PCB Stack: Test Fitting
Rimage
Battery Box: Folded stainless steel
Battery Board: Testing the board
Knock Knock: Testing the sensor circuit
Protoshield: Surely I can fit more on it than this...
Knock Knock: Now on stripboard
Fibre Housing: With fibres
Just add magnets: Hans and Matilda get an upgrade
Top Panel: Buttons and lights
Printing Supports: Attempt 6
Buttons: Circuit board for the top panel
Fail: When buttons go bad
Magnet Holders: Hans and Matilda out up front
Magnet Carriers: The new mechanism
Posing: finished cottage
Electronics: Hans and Matilda admire the finished electronics
Weather: Warm, slight chance of rain in Chicago
    balearicdynamics over 11 years ago in reply to Workshopshed +1
    Thank you Andy, as I have no idea of what the name is I wasn't able to search for them. It is the first time I see them. Enrico
  • Workshopshed
    Workshopshed over 11 years ago in reply to mcb1 +1
    Yes, I have used those, I like how they thread in using an Allen key. Actually thinking back it was those I used for the grinder, not captive nuts.
    Maybe this sounds strange to you but now I have clear what you meant. Thank you. I have used this stuff but no idea that there was also something in a smaller scale. Enrico
    Great Andy, this post complete the project and creation scenario.
    And suggest me a question that I forgot to ask you when I saw this (in the image below) for the first time. What is it exactly? Where did you found it? I am curious. about this method to join some parts you have adopted.
    Enrico
  • Workshopshed
    Workshopshed over 11 years ago in reply to balearicdynamics
    They go by different names such as TNuts or Captive Flange
    http://www.modelfixings.co.uk/captive_nuts.htm
    Enrico
  • Workshopshed
    I also used some larger ones to clamp my grinder to the bench with some large bolts, it avoids the need to get a spanner into tight spaces and they can be thinner than regular nuts.
  • Workshopshed
    mcb1 over 11 years ago in reply to Workshopshed
    Have you seen this range of thread inserts for wood.
    http://www.edlfast.co.nz/products/index.php/nuts.html?cat=3427
    They come on various size threads from M4 to M8.
    The unflanged have not lip so can be wound down below the surface.
  • Workshopshed
