Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Enchanted Objects Design Challenge - Photo Story
  • Author Author: Workshopshed
  • Date Created: 25 Jun 2015 5:06 PM Date Created
  • Views 1885 views
  • Comments 8 comments
  • enchanted_cottage
  • enchanted_objects
Workshopshed
Workshopshed
25 Jun 2015
Some photos that were taken during the project.
{gallery:width=600,height=600} Photo Story
Enchanted Cottage: Before it was taken apart.
Mechanical Prototype: Cardboard and brass tacks
Multiprint: Printing lots of parts for the mechanism
Test Jig: For testing servos
Cutting: Strips of wood for the substructure
Planks: Initial pass at the frame parts
Printing: Printign the mechanism
Battery Delivery: Matilda checks out the new battery
Captive Nuts: Nuts to support rods to support PCBs
Battery Test: Testing the battery
Infineon Low Power: Testing low current options with the Infineon RGB Shield
LED: A mini PCB
Golem: Hans and Matilda's Metalworking Friend
Pins: Pins and Headers
Rimage
PCB Stack: Test Fitting
Rimage
Battery Box: Folded stainless steel
Battery Board: Testing the board
Knock Knock: Testing the sensor circuit
Protoshield: Surely I can fit more on it than this...
Knock Knock: Now on stripboard
Fibre Housing: With fibres
Just add magnets: Hans and Matilda get an upgrade
Top Panel: Buttons and lights
Printing Supports: Attempt 6
Buttons: Circuit board for the top panel
Fail: When buttons go bad
Magnet Holders: Hans and Matilda out up front
Magnet Carriers: The new mechanism
Posing: finished cottage
Electronics: Hans and Matilda admire the finished electronics
Weather: Warm, slight chance of rain in Chicago
    balearicdynamics over 11 years ago in reply to Workshopshed +1
    Thank you Andy, as I have no idea of what the name is I wasn't able to search for them. It is the first time I see them. Enrico
  • Workshopshed
    Workshopshed over 11 years ago in reply to mcb1 +1
    Yes, I have used those, I like how they thread in using an Allen key. Actually thinking back it was those I used for the grinder, not captive nuts.
    Maybe this sounds strange to you but now I have clear what you meant. Thank you. I have used this stuff but no idea that there was also something in a smaller scale. Enrico
    Great Andy, this post complete the project and creation scenario.
    And suggest me a question that I forgot to ask you when I saw this (in the image below) for the first time. What is it exactly? Where did you found it? I am curious. about this method to join some parts you have adopted.
    Enrico
    Enrico
  • Workshopshed
    Workshopshed over 11 years ago in reply to balearicdynamics
    They go by different names such as TNuts or Captive Flange
    http://www.modelfixings.co.uk/captive_nuts.htm
    Enrico
  • Workshopshed
    I also used some larger ones to clamp my grinder to the bench with some large bolts, it avoids the need to get a spanner into tight spaces and they can be thinner than regular nuts.
    mcb1 over 11 years ago in reply to Workshopshed
    Have you seen this range of thread inserts for wood.
    http://www.edlfast.co.nz/products/index.php/nuts.html?cat=3427
    They come on various size threads from M4 to M8.
    The unflanged have not lip so can be wound down below the surface.
  • Workshopshed
