Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog Enchanted Objects Design Challenge - The Woodcutter and the Blacksmith
  • Author Author: Workshopshed
  • Date Created: 30 Mar 2015 6:53 AM Date Created
  • Views 3041 views
  • Comments 21 comments
  • enchanted_cottage
  • enchanted_objects
Workshopshed
Workshopshed
30 Mar 2015
The Woodcutter
Matilda needed some wood for the house extension so she set off through the forest to visit the woodcutter. She found him in a clearing formed by trees that had fallen in the same storm that had damaged the enchanted cottage. "Several trees fell during the storm" said the woodcutter, "but I did not hear them". The wood cutter pointed to the young sapling amongst the fallen trees. "The sapling bends with the wind but the oak breaks" he said. Matilda thought maybe the woodcutter spent a bit too much time on his own.
Matilda showed the wood cutter her plans for the basement and rear extension to the enchanted cottage.
The woodcutter set about one of the fallen trees and soon had it converted into planks for Matilda's design, she helped him load the into the cart and then headed off to see the blacksmith
The Blacksmith
Matilda always liked visiting the Cel the blacksmith as it was always nice and warm in his shop. She showed Cel the plans for the Watt's linkage and the he set about making the first parts.
When the tested them the pins were too weak and one snapped off. They both cursed at the wasted time and discussed an alternative. Their second attempt was successful and used a hardened screw to re-enforce the joint.
Matilda redesign all of the parts to work this way and left the plans with the Blacksmith who set about making them.
There were a few changes to the parts over the next few hours but eventually Matilda has a set of components she was happy with.
By the time she had returned home, Hans had finished the repairs to the roof
{gallery:width=300,height=400}Roof repairs
Roof Glue up
Roof battens
Roof back on
The next job for Matilda was to put the parts into motion and her thoughts thoughts returned to the words of the woodcutter. Perhaps she thought, rather than directly connecting the servo to her mechanism she could use a springy sapling. Then if anything locked up the sapling would flex rather than causing the servo or mechanism to break.
Next Enchanted Objects Design Challenge - Back on the straight and narrow
    mcb1 over 11 years ago +2
    left the plans with the Blacksmith who set about making them Funny how they are plastic ... are you sure Cel is a blacksmith and not farming it out to some cheap alternative labour source?? Maybe Cel…
  • Workshopshed
    Workshopshed over 11 years ago in reply to mcb1 +2
    I was thinking a springy wire, something like this From RC Boat Rudder Linkage
    mcb1 over 11 years ago in reply to Workshopshed +2
    That might work as well. Several ways to skin the cat so to speak.... Mark
  • gadget.iom
    gadget.iom over 11 years ago
    Hilarious! image
    The enchanted cottage is coming along nicely. An excellent write-up as usual.
  • Workshopshed
    Workshopshed over 11 years ago in reply to gadget.iom
    Yes, am on schedule and the Yun arriving today means that I've no critical path items. Only purchase remaining is for battery power although I do have a miniature 6v lead acid if I get desperate!
    Still plenty to do thought!
  • gadget.iom
    gadget.iom over 11 years ago in reply to Workshopshed
    At least the lack of battery shouldn't delay development too much. image
  • gadget.iom
    How much would it take to convince Matilda that solar panels on the roof may reduce their energy bills?
  • gadget.iom
  • Workshopshed
    I do have some panels but they are about 10 times the size of the house image
  • gadget.iom
    She may take exception to that. image
    Have you looked at some of the cheap Solar Garden lights.
    I know many are 1.5v only, but with two in series and one of those super efficent boost converters, it might do the trick to charge up a LiPo.
    I know its extra, but worth the tale that accompanies the pictures ...image
  • Workshopshed
    Mark, I'm not ruling it out but still have to get an estimate on power consumption and hence battery size.
    I'm hoping to do some quite aggressive power management with the Yun to get my amp hours down but suspect I'll need more than a couple of small panels can provide.
  • Workshopshed
    I've decided to check with a solar expert....
