Enchanted Objects
  • Enchanted Objects
Enchanted Objects
Blog MagicHat - 5 - Blood pressure sensor
  • Author Author: amgalbu
  • Date Created: 2 Apr 2015 12:22 PM Date Created
  • Views 1933 views
  • Comments 9 comments
  • enchanted_objects
  • pulse_sensor
  • heart-rate
  • magic_doctor_hat
amgalbu
amgalbu
2 Apr 2015
I made some modifications to the original circuit I talked about in my previous post and made it on a bread board. Here is the resulting circuit
I placed my finger on the sensor, and I got a quite clean signal
The signal is 200 mV peak-to-peak. Since the ADC has a 10 bits resolution over a 5V range, the signal will be read as 80 ADC steps, which should be enough to make heart beat detection easy
  • amgalbu
    amgalbu over 11 years ago in reply to Workshopshed +1
    Hi Clark Thanks for your comments!! Actually mi idea was to use the Arduino Yun to detect heart-beat (both IBI and BPM). I think there is enough power in the Atmel328 for that task! My only doubt is wthether…
  • Workshopshed
    Workshopshed over 11 years ago in reply to amgalbu +1
    www.youtube.com/watch
  • amgalbu
    amgalbu over 11 years ago in reply to amgalbu +1
    Sorry, Arduino Yun has a Atmel324
  • Workshopshed
    I was watching the EEV blog the other day and Dave was looking a.t an old speach recognition circuit. That used a comparator to turn audio into a square wave and the frequency was read directly via a digital pin on the microcontroller. Obviously if you are using the SAM to analyse the signal you might do that in software.
  • amgalbu
    Hi Clark
    My only doubt is wthether to increase gain or not... during my tests I saw that noise increases too, so I think what you see on the scope I the best tradeoff I can currently get. Probably a two-stages amplifier would perform much better
    Cheers
  • Workshopshed
  • clem57
    clem57 over 11 years ago in reply to Workshopshed
    http://www.bizapedia.com/ca/VOICE-CONTROL-PRODUCTS-INC.html a listing for the company he mentioned for the chip. It basically went defunct!
    Clem
  • amgalbu
  • amgalbu
  • Workshopshed
    Yes, a bit more RAM than the Uno and it behaves more like the Leonardo in that it does not have a separate USB chip so you need to watch resets.
