Documents Experimenting with Current Sense Amplifiers Challengers
  • Author Author: pchan
  • Date Created: 28 Mar 2022 9:03 PM Date Created
  • Last Updated Last Updated: 29 Mar 2022 1:57 PM
  • Views 3094 views
  • Comments 5 comments
profile image sensors
About Competition | Blogging | Example Application | Resources | The Dates | The Prizes | The Kit | The Judges | Terms & Conditions | The Challengers
Welcome to the Experimenting with Current Sense Amplifiers challengers page!
Our Experimenting with Current Sense Amplifiers Competition a(n) collaboration/association with Maxim Integrated, has now launched.  The 10 challengers will use the current sense amplifiers kit to experiment use, application, response, and more.  These Challengers will receive a Challenger Kit for FREE.
Please join us in congratulating the official sponsored Challengers.  We look forward to reading all your initial blogs introducing your project designs.
aspork42 | colporteur | Gough Lui | guillengap | milosrasic98 | misaz | taifur | ujjwalrathod00700 | vinayyn | vishwasn
Current Monitoring for safer 3D Printers
aspork42's project blogs
Model Train Block Detection Using Current Sense
colporteur's project blogs
A Bench Supply Current Monitoring Upgrade
Gough Lui's project blogs
High Precision Calibration of Piezoresistive Pressure Sensors with the MAX40080
guillengap's project blogs
Rover Motor Control
milosrasic98's project blogs
USB Type-C PD Monitoring
misaz's project blogs
Smart Power Bank Controller
taifur's project blogs
Tuning the Parameters for Optimum Use of MAX40080
ujjwalrathod00700's project blogs
Electrical Bicycle Battery Consumption Monitor and Pedal Assistant Guiding System
vinayyn's project blogs
Predictive Maintenance of High Speed Telecom Equipments
vishwasn's project blogs
Congratulations to all our selected challengers!
Good Luck Everyone!
  • misaz
    misaz over 4 years ago in reply to zst123 +1
    Sensor is sensing at high speed but output speed is limited by I2C speed. See datasheet for more details, calculations and limits. TLDR version is that chip can communicate at super fast 3.4 MHz I2C, but…
    dougw over 4 years ago +1
    Congratulations to the challengers. Some interesting projects. Looking forward to see how they pan out.
  • zst123
    zst123 over 4 years ago in reply to misaz +1
    Oh yes I didn't think about it. Indeed the datasheet does have a nice chart. 60ksps will be the fastest for real-time streaming of data. Nevertheless, there are some features that may still make it…
  • zst123
    Congratulations to the challangers. I submitted a last minute proposal and didn't have time to think of convincing enough solution.
    Looking forward to the blogs. I'm particularly interested and hope to see some tests on the high speed capabilities of the MAX40080.
    Seems like it can sample up to 1 Msps and possibly can capture some current transients in detail. Open mouth
  • zst123
  • misaz
    Sensor is sensing at high speed but output speed is limited by I2C speed. See datasheet for more details, calculations and limits. TLDR version is that chip can communicate at super fast 3.4 MHz I2C, but very few constrollers supports this. Even on Raspberry Pi it will be very tricky to configure I2C controller to run on this speed. You cant read more than about 60k samples over I2C (60k is maximum at 2.88 MHz I2C bus calculated in datasheet at page 34). High sampling rate is used for averaging (digital filter) multiple samples (up to 128) to one output. Datasheet contains much more calcualtions and estimations about this, but RAW 1 MSPS is definaly impossible to get from this.
    It would be nice to see some details. I think that even with filtering enabled some details could be seen but main purpose of this chip is to monitor long term average consumption. It has some peak related features like comparators which can analyze every of 1 milion samples per second, but this in-chip feature and it is hard to get all of these measured values out of this due to serial bus choice.
  • zst123
    Nevertheless, there are some features that may still make it work, like comparators you mentioned. Perhaps the last 64 samples can be saved upon detecting a current transient. But at 1 Msps it would mean only 64us worth Thinking
  • aspork42
    aspork42 over 4 years ago in reply to zst123
    I'm hoping to capture some high-speed transients with my project. Don't know how much success I'll have though.
