Experimenting with Waterproof Connectors
  • Experimenting with Waterproof Connectors
Blog LattePanda Chassis
Join Experimenting with Waterproof Connectors to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 28 May 2023 2:53 AM Date Created
  • Views 848 views
  • Likes 9 likes
  • hammond ip68 enclosure
  • waterproof webcam
  • waterproof camera
  • experimenting with Waterproof Connectors
  • lattePanda V1
LattePanda Chassis
dougw
dougw
28 May 2023
Intro
In this episode of the waterproof connectors experimenting challenge I am building the computer and display at the top of the pole. The chassis allows the system to be handled without touching the circuit card.
I had to design a chassis for the LattePanda because the metal heatsink case I ordered has not arrived. The 3D printed parts took about 10 hours to print.
Design & Build Video
Here is s video showing how it was designed and built:
Discussion
Fortunately, everything printed nicely and everything fit well.
It is tough to video detail on something this size - even fitting it on the bench is an exercise.
I used this blog as an opportunity to experiment with some new video software. (OBS)
The build is close to complete, which is fortunate because the experimenting deadline is only a couple of days away.
I am including the 3D print files in case anyone else wants to mount a LattePanda on a hockey stick.
LattePanda.zip
Next Steps
  • Obtain a mini HDMI cable
  • Connect a battery
  • Perform some water tests
Links:
 Sub-Surface WebCam
 Waterproof Connectors - Camera Build
 Pole Mechanism for the Waterproof Camera
LattePanda and LCD Pole -Mounted Chassis
Underwater Camera Test
Hammond and Amphenol Experience
 Subsurface Camera Using Amphenol Waterproof Connectors and a Watertight Hammond Manufacturing Enclosure
 Experimenting With Waterproof Connectors
    beacon_dave over 3 years ago
    If using it outdoors, then you may find that you need some sort of shade for the display. If you can make it flip open, then it can double as a screen protector when folded shut.
