Design Challenges
Design Challenges
Forum Design Challenge Prizes - What Do You Want?
  • Blogs
  • Replies 78 replies
  • Subscribers 24 subscribers
  • Views 7760 views
  • design_challenges
  • prizes
nlarson
nlarson over 11 years ago
For those of you who have applied to compete in a Design Challenge at element14 Community what prizes did you feel motivated you the most to sign up? If you haven't applied, what prizes would motivate you the most to sign up and compete?  What prizes would you like to see that haven't been offered yet?  Does a goodie bag of products get you motivated? How about a chance to meet and spend a day with your electronics engineering "celebrity" or maybe mentoring sessions from an industry expert?
Please share your thoughts below to help us make prizes better for future Design Challenges.  (cc: Members Top Members RoadTests & Reviews element14Dave)
Thanks!
    dougw over 11 years ago in reply to Robert Peter Oakes
    Yes I have a Cel Robox.
    It worked well from day 1.
    I print in normal resolution - it is fine for all my needs and the surface on the PEI comes out as smooth as glass.
    The PEI surface is spectacular - really good bond when hot and parts just pop off when it cools down.
    The heat seems very uniform - I have printed maximum size flat panels and they adhere well everywhere while printing.
    The self calibration at the start of every print is accurate enough that there are no problems with prints.
    That is not to say that I don't have any problems, for a while I was getting some stringy hair when the valve wasn't closing properly during non-printing traverses - but it cleared itself after one print. There are a lot of little things to learn about making good prints, but I am not good about recording all the things I try, because it isn't clear before hand what will work and what won't - but then suddenly some little thing makes a big improvement.
    As a rough guess about 80% of what I print turns out fully functional as planned on the first try. The other 20% is probably split between my measurement errors, design errors and printer failures. Some of the printer failures are simply things like the PLA filament is wound so tightly on the spool it won't feed off the spool. This is easy to free up on the fly, but with prints that take many hours it is not possible to be beside the printer at all times. The printer is actually pretty good about restarting after a filament jam, even hours later, but sometimes it leaves a gap that ends up in an area that is too weak in the finished part. Sometimes it can be fixed with glue.
    All in all I am very happy with my Robox printer - it is about as easy to use as these devices can be and it has been surprisingly robust and surprisingly useful.
    You need to figure out a way to get your printer tuned up - it will be worth it.
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago in reply to dougw
    Do you have the rebox
    if so
    what is you main printed filiment
    do you print on fine, normal, custom
    do you have any issues with a un even bed (PEI does not sit perfectly flat ont he aluminium heat spreader ) causing the first layers to bottom out so no filement layed down and or not adhear to its neibours
    other common issues ?
    As yo may be guessing, I am having these issues
  • ntewinkel
    ntewinkel over 11 years ago in reply to Workshopshed
    I just happened across your comment again image
    So here is my review...
    I found that the course focuses mostly on learning the electronics that go around robotics for sensors and outputs, not so much the robotics themselves. There's nothing on software other than that they provide the code required to run the project.
    There's also a lot of detail on the theory behind the circuits.
    For me it was a little too much, though still very interesting. But I learned some very useful things about filters and amplifiers.
    One part I wondered about was that they were creating complex circuits which I think could have been done by using an ADC on the chip instead.
    -Nico
    dougw over 11 years ago in reply to clem57
    Clem,
    I like my 3D printer a lot - it is in almost constant use.
    I actually have almost everything on that list, except #3 and #7.
    It is a list of what members might like ... I want #3, #7, #11 & #12
  • clem57
    clem57 over 11 years ago in reply to dougw
    dougw
         Why #2, do you not like yours?
    Clem
    BTW, vouchers work well if you have too many interests like me.
    balearicdynamics over 11 years ago in reply to dougw
    3D printer and e14 vouchers...
    dougw over 11 years ago in reply to dougw
    1. oscilloscope
    2. 3D printer
    3. 3D scanner
    4. camera for video blogging
    5. camera for macro photography
    6. bench power supply
    7. signal generator
    8. accurate DVM
    9. electronics CAD software
    10. android phablet
    11. prototyping breadboards and general purpose modules like PSoC kits, arduinos and RPi's
    12. e14 vouchers
    updated to an even dozen...
  • clem57
    clem57 over 11 years ago in reply to Workshopshed
    Nice, but $3K?
    Clem
  • kidiccurus
    kidiccurus over 11 years ago
    My personal motivation is not so much then prizes at the end of the challenge but the materials given to entrants. Seeing the high value prizes is nice, but knowing that I will receive some nice dev boards if I am successful in entering is great motivation as it garuntees me some return on my effort. Including more parts than needed for the challenge is a great way to do this as it also allows multiple approaches for people to tackle the challenge. For example, the inclusion of both an LED and motor sheild in the enchanted objects challenge allowed me to include a nice bachlight in my project after I managed to remove the need for the motor sheild, and the Arduino Uno that was supplied is now used regularly for other projects. A finishers prize, as mentioned earlier, does also seem like a great idea. Orphaned projects are very sad, and anything that reduces the quantity of them is definitely a plus in my book.
      One other small thing regarding the main prizes, I personally do not particularly like apple devices, and so a macbook is not a great incentive for me. I value the upgradability and modification opportunities offered by Windows and Linux far more than the nice design of apple products.
  • Workshopshed
    Have been looking at EPaper dev kits, they seem quite expensive for what they are, might be good to be able to roadtest one of those.
