Blog Forget Me Not : LPG Level
  • Author Author: mcb1
  • Date Created: 28 Sep 2014 6:29 AM Date Created
  • Views 3366 views
  • Comments 13 comments
  • forget_me_not
  • b+
  • design_challenge
  • openhab
  • iot_eldermon
  • tektronix
  • eclipse
  • internet_of_things
  • enocean
  • raspberrypi
  • smarthome
  • challenge
  • iot
  • enocean_pi
mcb1
mcb1
28 Sep 2014
This post is not really for my challenge. but struck me as being another product looking to be hacked ....image
Link to other posts
Forget Me Not : eLDERmon Intro
Forget Me Not :  eLDERmon  Electrical
Forget Me Not :  eLDERmon  Outlets
Forget Me Not : eLDERmon Planning
Forget Me Not : eLDERmon Parts 1
Forget Me Not :  eLDERmon  Sponsor Parts
Forget Me Not : eLDERmon Hardware Hacking
Forget Me Not : eLDERmon GNUplot
Forget Me Not: eLDERmon Protocol
Forget Me Not : eLDERmon Hardware Hacking #2
Forget Me Not : eLDERmon Hardware Hacking #3
Forget Me Not : eLDERmon Tim
Forget Me Not : eLDERmon Charts
LPG Level
While I was purchasing some products in a local electronics retailer, I spotted this.
http://www.jaycar.co.nz/productView.asp?ID=QM1662&CATID=97&form=CAT2&SUBCATID=946#1
I knew Inderpreet  ipv1  was looking at measuring his LPG tank, and because this was so cheap, I had to buy it.
I've done nothing more than opened it and take the photos. (click on them for full size)
The unit takes AA batteries , and the metallic portion on the rear is magnetic.
A closer look inside
It appears to have a PIC 12F675 chip which drive the two ultrasonic transducers and then the LED's and speaker when the level is low.
Just what R6 does is anyone's guess.
I got curious so I put it on our Bottles.
Its not extremely loud (I wasn't able to simulate the drop in level), and the LED's only briefly flash.
It's designed for a BBQ rather than fixed cooking bottles, but could be modified to add a small RF device.
I'm also not sure what the local insect population would make of the new home, and I'm certain it wouldn't take long for something to take up residence.
They are distributed by Electus
Electus Distribution
Enough distractions back to me challenge.
    shabaz over 12 years ago in reply to mcb1 +1
    I saw a couple of the Minions at the local toy store - I couldn't decide which one to get (for the nephew of course : )) but I spent a good five minutes triggering their every response : ) It doesn't get…
    mcb1 over 12 years ago in reply to fvan
    I took him to work yesterday (someone went sick), and I managed to distract every Air Traffic Controller ... so we decided he was a bit distracting and put him away.
    Maybe hacking him might be a good move.   image
    I'd like to be able to force a particular sound.
    maybe later ...I have other things to concentrate on.
    BTW my openHAB is stable so it must have been the changes...
  • fvan
    fvan over 12 years ago
    Never run out of gas halfway through a barbie ever again
    You're becoming quite the hacker. When is it Tim's turn to be hacked ? image
    Frederick
  • ipv1
    ipv1 over 12 years ago
    Thanks for the teardown sir.
    I was not sure what kind of ultrasonic transducers were used but for the price they are worth it. There are fluid sensors in the element14 catalog but they are not cheap.
    The problem with this setup is that you cannot find out the rate at which the storage is being emptied as well as no projections can be made regarding when a refill will be needed. I'm testing the weight based system and I like the results.
    The only blunder I have made is using a single load cell. The better arrangement would have been three 20Kg Load Cells in a balanced tripod for a wieghing machine kind of system. I will be upgrading it once I am done with the current version.
    Many thanks again.
    Regards,
    IP
