In the Air Design Challenge
  • In the Air Design Challenge
Blog Dust, Temperature and Humidity Monitor Chapter 4
  • Author Author: engswee
  • Date Created: 20 Nov 2014 3:54 AM Date Created
  • Views 990 views
  • haze_monitor
  • in_the_air
engswee
engswee
20 Nov 2014
(Best view 1900 x 1200)
This chapter I just sharing with all about component and sensor that plan to get.
I will develop hardware in parallel for BBB and CC3200. Both system have pros and cons for example the CC3200 have an build in WIFI which BBB don't have.
But the main reason is because I not really strong in programing especially high level programing and Linux OS.
So this will prepare me with two ready for programing hardware because at this stage I don't know which platform will provide the best outcome in programing and management.
But base on experience CC3200 look more similar with my daily platform micro controller and BBB look more like a small computer.
Given Component:
BBB
Long story at 126 page huh... image
http://www.farnell.com/datasheets/1819364.pdf
CC3200
This also have some story at 66 page another huh...
http://www.farnell.com/datasheets/1833194.pdf
MSP-EXP430FR5969
This one better with 38 page.
http://www.farnell.com/datasheets/1824797.pdf
This all not included the link given which will increase more page...
Next is must have Design Kit from Würth Elektronik. They come in nicely heavy duty box and nicely organize container.
With the plus is they also come with anti static tweezers.
I will recommended to all R&D engineer or anyone in circuit design.
Nice and solid box. No affect at all with my 2 year old daughter step on it.
Very good container with information and picture about the component inside.This help a lot when searching for component.
There also prepare a place for tweezers where perfect touch here.
Well design and labeling for all component inside.
Will make use of this when design the DC-DC in future.
Really more than you expect. Nice product recommended to all.
Part list from Element 14:
Part can added to parts list using given link below. Part webpage also can be access by click the Element 14 order code below.
430BOOST-SHARP96430BOOST-SHARP96
BB VIEW_43   BB VIEW_43   or  BB VIEW_70BB VIEW_70
SHARP - GP2Y1010AU0F - DUST SENSORSHARP - GP2Y1010AU0F - DUST SENSOR
SZH-003T-P0.5SZH-003T-P0.5
ZHR-6 - CONNECTOR HOUSING, 6WAYZHR-6 - CONNECTOR HOUSING, 6WAY
SENSIRION - SHT75SENSIRION - SHT75
SENSIRION - EK-H5SENSIRION - EK-H5
SUNON - EB40200S2-0000-999 - FAN, 40X40X20MM, 5VDCSUNON - EB40200S2-0000-999 - FAN, 40X40X20MM, 5VDC
ELEMENT14 - WIFI DONGLEELEMENT14 - WIFI DONGLE
MOLEX - 68786-0001 - MICRO HDMI CABLE ASSEMBLY MOLEX - 68786-0001 - MICRO HDMI CABLE ASSEMBLY
1
2429519TEXAS INSTRUMENTS
430BOOST-SHARP96
LCD BOOSTERPACK PIM, MSP430 LAUNCHPADimage Yes  SG 5 ,  UK 6    S$29.30
  S$58.60
Line Note:
  Accessories Available RoHS Compliant
2
2364756ELEMENT14
BB VIEW_43
4.3INCH LCD DISPLAY CAPE, FOR BEAGLEBONEimage Yes  SG 47 ,  UK 167    S$107.16
  S$107.16
Line Note:
3
9707956SHARP
GP2Y1010AU0F
DUST SENSORimage Yes  SG  0 ,  UK 366    S$17.53
  S$52.59
Line Note:
4
3357533JST (JAPAN SOLDERLESS TERMINALS)
SZH-003T-P0.5
CONTACT, CRIMP, RECEPTACLE, 32-28AWGimage Yes  SG 4904 ,  UK 25130    S$0.033    image
  S$0.99
Line Note:
  Alternative Products Available RoHS Compliant • Accessories Available RoHS Compliant
5
3357570JST (JAPAN SOLDERLESS TERMINALS)
ZHR-6
CONNECTOR HOUSING, 6WAYimage Yes SG 19947 ,  UK 9254    S$0.041    image
  S$0.41
Line Note:
6
1590514SENSIRION
SHT75
SENSOR, HUMIDITY & TEMP, 3.3Vimage Yes  US 0 ,  SG  71 ,  UK 32    S$40.56
  S$121.68
Line Note:
7
1924832SUNON
EB40200S2-0000-999
FAN, 40X40X20MM, 5VDCimage Yes  SG  15 ,  UK 382    S$4.47
  S$13.41
Line Note:
8
1855471SENSIRION
EK-H5
EVALUATION KIT, HUMIDITY, FOR SHT2X/7Ximage Yes  SG 15 ,  UK 0    S$78.86
  S$78.86
Line Note:
9
2127550MOLEX
68786-0001
MICRO HDMI CABLE ASSEMBLYimage Yes  US 376 ,  SG 0 ,  UK 0    S$24.45
  S$24.45
Line Note:
10
2437981ELEMENT14
WIFI DONGLE
USB DONGLE, WLAN, 150MBPSimage Yes  SG 91 ,  UK 936    S$19.40
  S$19.40
Line Note:
Going to get component:
430Boost-sharp96 - 20 page
Plan to use this with CC3200 and MSP-EXP430FR5969 for showing data information and work as front end GUI.
http://www.farnell.com/datasheets/1830501.pdf
BB view 43 - 48 page
Plan to use this with BBB for GUI.
http://www.farnell.com/datasheets/1824482.pdf
SHT 75 - 12 page
This is temperature sensor and humidity sensor (2in1). I choose this sensor because they are the best that I found that come with reasonable price tag.
(please let me now if anyone have better suggestion)
This sensor also come I²C digital output where user can get data with less issue with noise and ADC.
http://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/Humidity/Sensirion_Humidity_SHT7x_Datasheet…
Dust sensor - 12 page
The only dust sensor available to get on hand. Maybe need to consider the measurement laser system in the laboratory to replace this one.
Hm..m.. I don't think so. Look at the price, no way can use that system.
http://www.farnell.com/datasheets/73805.pdf
Other will be the support component like connector, fan, EK-H5, power bank and more.
I will not go into detail for support item unless it useful from my point of view.
Design:
We do it with cubic image
Design version 1.0.0 with placing all the part in the drawing.
Using multistage concept with each level dedicated for certain part or component. This will make installation, modification, debugging, assembly and other work easy in future.
Plan to use PCB as the base for each stage which can work as support and able to make connection header between them if needed.
Now having some placement issue to bring internal connection out of the box. Maybe the end design in not cube anymore image.
Right now just think of using acrylic or 3D printed nylon for this housing. Please let me know if anyone have suggestion image. Now just plan for local 3D printing service.
Picture show with transference housing to show the inside part. Current dimension is 120mmx120mmx120mm due to 4.3" LCD. But may change in future.
Other information:
Eclipse:
More information on IoT. This is presentation slide show more information about their product.
Building the Internet of Things with Eclipse IoT - JavaLand 2014
Kura-Kura mean turtle in Malay language image
https://eclipse.org/kura/downloads.php
Example for BBB with kura Eclipse
BeagleBone Quick Start
Sharing:
Thinking of making cube design for my sensor and look around internet I found this http://techcrunch.com/2014/01/07/cubesensors-brings-health-and-comfort-monitoring-to-the-whole-home/
Cube sensor product on market come with app and base station. More information: https://cubesensors.com/
Seat back for a while and rest.....
https://archive.org/download/49DaysPureLoveOst/49DaysOst-ShinJae-FallingTears.mp3
https://archive.org/download/49DaysPureLoveOst/download%2F49DaysPureLoveOst%2F49DaysPureLoveOst_vbr.m3u
Nature Wallpaper Beautiful Sunset
Nature
http://www.hdwallpapersinn.com/wp-content/uploads/2014/07/best-nature-top-hd-wallpapers-widescreen-cool-images.jpg
OK enough go back to work. he..he..
Previous:
Dust, Temperature and Humidity Monitor Chapter 3
Next:
Dust, Temperature and Humidity Monitor Chapter 5
    DAB over 11 years ago
    Good post and great pictures.
    You have some very nice sites to enjoy.
  • engswee
    engswee over 11 years ago in reply to DAB
    TQ DAB
    he..he..
    Just need to remove some code from the brain. Any better idea please share.
    Many more coming under sharing section image
    cheer
    ES
  • engswee
    TQ DAB
    he..he..
    cheer
    ES
