In the Air Design Challenge
  • In the Air Design Challenge
Blog [Firecracker Analyzer] Successful QFN Assembly
  • Author Author: ipv1
  • Date Created: 21 Feb 2015 12:59 PM Date Created
  • Views 2141 views
  • Comments 7 comments
  • iot_firecracker
  • smd
  • ip_iot
  • bq25504
  • in_the_air
  • texas_instruments
ipv1
ipv1
21 Feb 2015
Not a very complicated post just a few pics of the assembly.
I use some flux and copper wire strands and used it to sweep the extra solder out... The above is the result and I check with the DMM to see if any pins were bridged. They weren't image.
I then moved on to solder the rest of the parts and...
Viola! All I need to do is mount the coil and connect the inputs and outputs. This should be fun...
    DAB over 11 years ago +2
    Indeed, your eyesight and steady hand are impressive. DAB
  • gadget.iom
    gadget.iom over 11 years ago +1
    Very impressive piece of hand-soldering.
  • tomaja
    tomaja over 11 years ago +1
    Your board looks great! Well done. Can you share the resistor values that you used to configure BQ25504?
  • ipv1
    ipv1 over 11 years ago in reply to DAB
    Thanks DAB sir. Hope this thing works... image
