In the Air Design Challenge
  • In the Air Design Challenge
Forum Subscription to AirVantage MQTT topic
  • Replies 20 replies
  • Answers 2 answers
  • Subscribers 5 subscribers
  • Views 4134 views
  • airvantage
  • in_the_air
tomaja
tomaja over 12 years ago
Hello people!
I'm having difficulties with MQTT.
Did anyone manage to "subscribe" to AirVantage MQTT server?
I never used a MQTT so I'm getting some difficulties when I try to get notifications when new data is published to AirVantage. Maybe I'm missing the point here? Should I get the updated values if I subscribe to some topic?
I call subscribe with MQTTLens or Paho test client but nothing happens after I publish new data (subscription to <SERIAL>/tasks/json appears to be successful). And I'm sure data is being published because I can see new values on Monitor -> Systems page in AirVantage control panel.
Hope someone can help.
Dragan
    e14 Contributor over 12 years ago in reply to tomaja +1 suggested
    No, the REST API to access AirVantage is decoupled from the device protocols: you can send data to the Cloud with MQTT or REST, to access the data you must use REST.
  • fvan
    0 fvan over 12 years ago
    Hi Dragan,
    I hope to be able to send some MQTT data to AirVantage this weekend. Will update you once I figure it out image
    Frederick
  • amgalbu
    0 amgalbu over 12 years ago
    Hi Dragan
    Which pattern do you use to subscribe? Try with '#' only just to be sure that you are subscribed to everything and see what happens
    Ambrogio
  • tomaja
    0 tomaja over 12 years ago in reply to fvan
    OK, thanks.
    For me, sending data is not a problem, the problem is notifying remote clients when new data is published.
    I will post a solution as soon as I resolve it.
    Dragan
  • tomaja
    0 tomaja over 12 years ago in reply to amgalbu
    Thanks Ambrogio!
    I was trying to subscribe to <SERIAL>/tasks/json and that does not work (subscription is successful but callbacks are never being called). Apparently, that topic is used to issue commands to clients.
    I also tried to subscribe to <SERIAL>/messages/json (the same topic that I publish data to) but that subscription fails.
    Do you think I should try subscribing to "<SERIAL>/tasks/json/#" of just "#"?
    Dragan
  • amgalbu
    0 amgalbu over 12 years ago in reply to tomaja
    I would subscribe to just '#', publish a message and see the topic received in the notification
    Ambrogio
  • tomaja
    I tried with just "#" but still got no result.
    Also tried with <SERIAL>/# but again, no message was received.
    I must have done something wrong during the AirVantage setup...
    Dragan
    0 e14 Contributor over 12 years ago in reply to tomaja
    AirVantage MQTT is not acting as MQTT broker.
    The first topic messages/json  to send data  (<SERIAL>/messages/json)
    the data are sent in the payload in json like this: { "machine.temperature": 23.2, "machine.humidity": 70 }
    If you want to receive data from AirVantage, you can subscribe to the second topic <SERIAL>/tasks/json.
    Didier
  • tomaja
    0 tomaja over 12 years ago in reply to e14 Contributor
    Thanks! I'm pretty sure I tried that but I'll check again and let you know the result.
    Dragan
  • tomaja
    Here's what I tried (serial is blurred but it's always the same):
    Values are being properly published, I see it when I use the AirVantage monitor.
    Am I doing something wrong here?
    Dragan
    what are you trying to achieve?
